not the inserts. the high durometer rubber bushings that replace the oem ones. does anyone else have these? I have some questions for people that do.
https://store.034motorsport.com/dogbone-mount-pair-density-line-mk5-mk6-volkswagen-8j-8p-audi.html
I'm talking about those in specific. I have the full set of density as well all 5 mounts. but when I installed those I cant say the same as you. I got lots of noises added to the cabin. huge amounts of vibration at really low rpms. fine once the car speeds up. and a transmission whine that wasn't there before sounds kind of like a dogbox at certain gears/rpms. I'm thinking of taking them out (just the dogbone) and just putting a stage 1 insert with stock. also thinking about reseating all my mounts. I love the feel they give on the track but the cabin noise is ridiculous for a daily
That's is completely normal for the full pucks. The vibration and whine comes with the fact you have solid bushings in the subframe now. A lot of noise gets transfered through them. That's a pretty aggressive setup for a street car, I run them on my racecar lol.
they are the density and its been like 6 or 7 months. the vibration doesnt bother me as much as the faint whine i can hear in certain gears and certain rpms and i have found several people that say its normal. i have 6mt so i can avoid the vibrations if i focus on what rpms im using. i found lots of car forums saying that stiff mounts can make whine audible. because they transfer noise to the cabin. and das apperantly has also experienced this. I've even seen a post in this forum about whine with just a stage 2 insert as well.
Absolutely, the factory goes to great lengths in selecting all bushings and mount materials to minimize cabin noise and vibration while not giving up all the performance characteristics. Once we start replacing those with stiffer parts you begin to hear/feel all those noises/vibrations the factory sought to isolate.
I have replaced all my mounts as mentioned and I have replaced all my suspension bushings with Whiteline poly components. I run stiffer suspension with larger sways etc. For me performance is more important than the extra noise and vibration. I have done this with all my cars and new noises and vibrations are just part of what happens when you start making these mods.
I understand and at this point i'm not really complaining I had just spent months trying to find the source of a noise that was just due to mounts so i was trying to see if anyone else experienced this with these specific mounts. because most posts i've found were from forums for other cars.
https://youtu.be/6AMmQbgezBo
https://youtu.be/DIGFt4b_3Xg
that is what i hear, its a whine. its not a leak i have a gauge and its not the turbo because it happens only at certain gears in certain rpms and i dont need to be in boost. in this video im accelerating very slowly and the car is at like 15 vacuum, i actually cant hear it in boost. it is also not intake harmonics because i even took the filter out and still hear it and again not throttle dependent just rpm/gear dependent. it started to happen after the mounts were installed. i cannot find the source of this noise. the transmission works perfectly. and the only thing i can find by searching online is that the mounts are transferring that noise to the cabin and that it was always there. doubt its a chipped gear too because it happens on 2nd 5th and 6th so i doubt all 3 are chipped. the noise doesnt change when I'm turning so its not wheel related. also not speed related because if i change to 3rd at the same speed the noise is gone.
