Some folks are drastically overthinking this...
The B8s are a bad @$$, highly versatile monotube damper.
To emphasize this point, compressing the piston rod on these new (front) struts took most of my strength and a lot of my bodyweight.
(speaking as a 225lb, career auto worker with arms like the rotating assembly in a diesel engine, and the dad-belly of a young Buddha who discovered beer).
1) These dampers are robust and will do extremely WELL if you put a GOOD quality spring on them.
2) They're an inch shorter than the stock struts, and the corresponding B6 strut offerings; both of which are for use with stock springs.
This makes the B8s compatible with MOST springs that are shorter than stock.
3) Having ENOUGH spring rate and static ride height to keep the B8s OFF of their internal bumpstops is most important.
Ask me how I know...
-H&R OE Sports didn't have enough rate, but come very close on the ride height. H&R Sports drop the car further and will ride like a skateboard because of it.
-APR Roll Control and EMD springs have produced terrible results for people over and over from insufficient rate + too much drop (not enough static ride height and usable stroke).
-VWR are a total tossup. Most VWR owners only street drive their cars or do to C&C parking lot meets. Let's be real.
So they may not be as sensitive/concerned about hitting bumpstops on bad roads, lack of corner control in fast sections of a road course or canyon road, etc.
4) The Neuspeed Sport springs for the GTI/R, and aftermarket S3/RS3 springs offered by Neuspeed and 034, are the ONLY MQB-compatible offerings I have found available (without moving to a dedicated coilover),
that provide the higher spring rates necessary to keep the B8s off their internal bumpstops, under hard compression and surface changes.
@tigeo found a bandaid method (no disrespect) that involves spring travel limiters on the H&Rs to keep the coils from compressing excessively on hard drips and bumps, to preserve the bump-travel of the B8s.
I am about to try the same, since it's a $15 experiment with parts/return warranty if the rubber isolators fail.
All that said, people need to quit asking "will this work with B8s?" and START asking:
"Where is the final static ride height with these HD springs on my much lighter 3100lb GTI (or 3300lb Golf R)?"
This is because the S3 spring options are for a 3460lb S3, and the RS3s are for a... (you guessed it) ~3600lb RS3.
Hope this helps some folks out who don't fully grasp suspension and chassis dynamics (which happens to be one of my 10 favorite subjects).
Let me know if I've failed to address anything else on the subject.
-The Feisty Goa
