► Official APEX VW SM-10 Flow Formed Wheel Thread
MonkeyMD
I'm 27 hours away but happy to make the drive if it's quicker
Johaan
Atlanta
So who is going to share the first installed photos?
zjchaser
OC, CA
16 GTI PP DSG
Darn. Mine are on but I had to run errands in my truck. Only have this photo from a little bit ago.
smashedpotatoes
Sacramento, CA
Golf 7 R
Thats a good amount of weights they put on there
I know, right? I was surprised at that too. Was consistent across all my wheels actually. I wonder if it was partially due to the Apex valve stems as opposed to regular rubber ones... But then again these weights aren't directly across from the valve.
jmblur
Massachusetts
2017 Golf R
Seems likely the shop was lazy and didn't rotate the tire to reduce the balance weight required, just slapped weights on there.
smashedpotatoes
Sacramento, CA
Golf 7 R
Now that you mention it, I think they may have put effort in the wrong area. Tech mentioned that he rotated the tire for "show mounting," which I hadn't heard of prior to today. Apparently it just means they lined up the DOT info with the valve stem? Correct me if I'm wrong. Is that a normal thing?
Millsn
Uk
Golf 7R
There's normally a small dot (red or orange im not sure) on the tyre that shows the heaviest point. The idea is to put the valve opposite that.
Daily Driver
New York
2020 GTI SE
Going to do some proper shots tomorrow
I like seeing more cellphone pics cause it gives me a more true to life look at the wheels vs the super edited by APEX. Im waiting to see the bronze and anthracite no Photoshop. Bronze is dull color but Apex shows it super shiny which may not be accurate. Unfortunately I didn't buy a set this time around I was doing power mods instead. Maybe in the next sale.
smashedpotatoes
Sacramento, CA
Golf 7 R
I went out this morning and took a closer look based on all of your posts. I counted approximately 10 weights in a row on one wheel (my others were similar), so roughly 2.5 oz per wheel. My tires also do not have marking dots pointing out the heaviest and lightest points on the tire, so the tech lined up my valve stem with the DOT info.
This article from Tire Rack regarding wheel weights says that the general industry standard is that the weights should not exceed 1% of the total weight of the wheel and tire assembly. In my case, 20.3# wheel + 23# tire (from TR spec) = 43.3# or 692.8 oz. 1% of that is 6.9 oz, and each wheel is well under that.
I agree that visually, it looks to be excessive. Could the shop have done a better job? Sure, I think they absolutely could have spent more time rotating the tire to get as close to zero weights as possible. However, for my use case, I don't think it's worth my time returning to the shop. The next time I need new tires, I will ask for them to try and minimize the amount of wheel weights used.
Thank you for helping me learn! :D
