LLV Racing
- Luckyllv28
- VW Golf R 2016
Hello,
I have a VW Golf R from 2016 and I have some problems with the cooling system.
When the car is fully heated, the coolant level is between minimum and maximum.
Every time I stop the car, I notice that the coolant in the expansion tank rises very quickly by 3-4 centimetres above the maximum level, even above half of the tank. When the engine cools down completely, the level drops by 2-3 mm but remains well above the maximum.
After I make a trip with it and the engine reaches the optimal temperature, the liquid level is again between minimum and maximum.
I connected an OBD 11 diagnostic and the temperatures at which it works are correct. A maximum of 107 C at idle and easy driving and drops to 85 degrees when I accelerate hard.
The coolant is clean without traces of oil, as well as the oil without traces of coolant.
The climate in the car works very well, it makes hot and cold.
I changed the whole water pump assembly but nothing changed.
What do you think could be the problem?
