Alright guys, new '16 GTI S owner checking in here a little late. Unfortunately my car has been afflicted with this dreaded "rear suspension noise". Within the first couple days of driving it I could tell something didn't sound right. It sounded just as some of you have described.. like a bunch of wooden logs jostling around in the trunk / boot at lower speeds when driving over any sort of rough / uneven road surface. Coming from nearly 6 years of driving my mk6 I knew this noise wasn't normal.
I brought the car back to the dealer to have them look at it. After they took it thru the car wash when I asked them NOT to.. One of the techs took it for a spin and supposedly put it up on the lift to inspect the rear. They said the tech couldn't replicate the noise and everything seemed fine but too bring it back in a couple weeks if the noise continued. I took my keys and drove off knowing something wasn't right.
After doing a little research I found Fuelboss's story about his issues with what I believe is the issue I'm having. Watching his YouTube video the sound the shock is making when he taps it is much like the sound I hear when I drive over even the slightest bumps or uneven road surfaces. Like a dull hollow clunk / thunking. Whatever the noise it is most certainly NOT a normal noise or something that is "characteristic of the model" as VW put it. I can say it definitely is NOT a noise the suspension should be making.
Since I believe the issue I'm having is the same as what Fuelboss has had, I'm debating on what I should do. I work 60 + hrs a week and simply do not have time to go back and forth to the dealer only to have them replace the shocks with a set that's going to start making noise again after a week like has happened to some of you. And that aside I don't want someone working on the car who took it for a ride and didn't think they heard anything wrong with it. I'm not a mechanic but I know when suspension is making a noise it shouldn't be. My plan right now is to purchase a set of Bilstein B4 OEM replacements and have my local mechanic (who I trust and worked on my mk6) install them. I'd rather fork up the cash for this and have it fixed right the first time then deal with the dealership and what will likely be a waste of time.
Moving forward, do any of you know a) where to order these Bilstein OEM shocks and b) exactly what I need to order part wise. Is it just the shock itself or do I need the entire assembly?
I'm not happy I have to deal with this, but if this will fix it I think I'll be happy with my mk7. Otherwise I really do like the car..
Sent from my Sprint iPhone using Tapatalk
