Hi, just an update , I’ve finally got round to doing the leak on the rear door speaker. I’d just like to give some insight for a novice like me who has to do this job.
There are a few videos on YouTube to watch first, on this subject but this is what I found. The 3 screws to remove first are T27 torx . The plastic screw on the bottom of the door turns 90 degree anti clockwise, then the door card can be pulled off... this is very tight until you get one loose then you can get get some leverage to remove the rest.. the cables are straight forward to remove then the card comes away and you can get down to removing the speaker.... this is where I messed up , I used a drill to small and the rivots started to spin and slightly damaged the speaker mounting holes.. You need a 4mm drill.
I then put silicon on the speaker and started to rivet it back on. But the nose of the rivot gun was to wide, so that made it awkward to get on the rivot square. Replacing the rest is straight forward... hope this helps somebody
