Install log.
Pressed a template on top with some paper, marked the cutout based on vents+scoop area.
https://photos.app.goo.gl/OV1wBh515ZS4bXQZ2
Hand placed to determine if radiator support stuff would be an issue, didn't seem like it.
https://photos.app.goo.gl/8rVERCvku8hAnyV92
https://photos.app.goo.gl/ci3ibqLTlMzRYgwY2
Drilled 4 holes into grill at corners of cutout, connected with sharpie.
https://photos.app.goo.gl/ZaCnsQtm9MPhRERe2
Roughed out with dremmel cutting wheel.
https://photos.app.goo.gl/GLXyRPbrkjwBpYjb2
Test fit was spot on.
https://photos.app.goo.gl/zqf2fWJ6JXK8ywm53
Drilled through the four pre-made holes and screwed in. Saw the upper left hole mostly lined up with a larger, existing hole already in the grill. Made a new hole a bit to the right of the existing one. Cleaned up the roughed cutout and tightened everything up. Snug as a bug. First problem was when I went to put the bumper back on I realized my new upper left screw was making contact with some plastic and I couldn't push the grill flush. I had to move my hole again to the right to clear that. Got everything tight and back together.
https://photos.app.goo.gl/Clux2A6Twe2TXLjy2
Radiator stuff did end up pressing on the left side of the scoop, enough to bend the grate a little bit at the front. No big deal, just need a couple more screws to hold it down in the front. 2slow is going to look at his and see if he can revise, but I think my IE IC just makes everything stick out a bit more.
https://photos.app.goo.gl/GPJAaIA01IJxrxd63
Only thing I'd do differently to fix it is just mount it a little more forward on the grill to avoid the pre-existing grill hole from lining up, and to move the scoop a bit further out from the radiator mount stuff.
It's raining, 33 degrees, and my summer wheels are on, because I am dumb. So butt dyno stuff is going to have to wait a bit.
