Lorenas: hmm........enabling TPMS is a little more involved than just setting Byte 4, Bit 0 in the dashboard module.
I've not done this tweak, but I understand that the following changes are also required:
Information Control Unit 1 (@ address hex5F)
Search for "Vehicle function list BAP"
Select "tire_pressure_system_0x07" and set to "active"
Select "tire_pressure_system_0x07_msg_bus" and set to "Suspension data bus"
Search for "Vehicle menu operation"
Select "menu_display_rdk " and set to "active"
Select "menu_display_rdk_over_threshold_high" and set to "active"
Brakes 1 (@ address hex03)
For EU+ mk7 vehicles, set Byte 27 Bits 4,5,6
Set Byte 28, Bit 7 to enable TPMS through the CAN bus
As I say, I've not tried this tweak
Don
