TwinDad
- Fort Lee, NJ
this is definitely cool, but trying to understand it is difficult. There are so many variables that can effect your boost and other things. I can run map 2 today and get no timing pull then run it next week where the temperature is slightly different and show some pull. You are a genius for sure, but this would help find a good safe map opposed to an all out, max power map.
There are always variables that can affect timing pull. That's why George posted about some saying 5 degrees is ok on this ecu, but he prefers 2 or less. Others feel that here should be none. One of the logs for an apr tune showed corrections like crazy. I think as long as you follow George's advice of no more than 2 degrees of corrections, you will be safe. It's always good to check logs when the temperatures change a lot though.
