It might be due to the lack of IC causing the iat rise mid rpm range to the end.
I don't see any cylinder timing pulls, but also you are lacking the timing advance on ig1. most logs i've seen get around 10 at the end, but yours show only max at 6 ish advance.
I also do not see any rpm spike (i thought if your dsg slipped, rpm spike would be present. please correct me if my assumption is wrong).
