Ramon64124
Kansas
http://www.datazap.me/u/ramon64124/042517-1-2?log=0&data=1-2-3-4-11-14-18-25-26-27&mark=31
Here is a new log with the help of George. still working. Seems to be running really strong up top and timing seems good. Going a little aggresive.
Looking for options to add E85 as the nearest one is 10 miles away from me.
current setup. Removed .5 from 5500-6000 due to timing drop.
1500 1.0
2000 3.0
2500 3.5
3000 4.5
3500 5.5
4000 6.5
4500 7.5
5000 8.5
5500 8.0
6000 8.0
6500 9.0
7000 8.0
Diggs24
de plains! de plains!
2015 GTI
1500 1.0
2000 3.0
2500 3.5
3000 4.5
3500 5.5
4000 6.5
4500 7.5
5000 8.5
5500 8.0
6000 8.0
6500 9.0
7000 8.0
Looks good.
psychonosspaz
PNW
1500 1.0
2000 3.0
2500 3.5
3000 4.5
3500 5.5
4000 6.5
4500 7.5
5000 8.5
5500 8.0
6000 8.0
6500 9.0
7000 8.0
Man that's aggressive
Perry01
Hawaii and Utah
1500 1.0
2000 3.0
2500 3.5
3000 4.5
3500 5.5
4000 6.5
4500 7.5
5000 8.5
5500 8.0
6000 8.0
6500 9.0
7000 8.0
What modifications and fuel?
wy2sl0
Ontario
I did and now it is hitting it. However, it decided on its own targets to hit rather than what I wanted. Still hitting higher boost than additive. JB4 has a mind of its own.
Could you please share your settings? I am basically at +6.0 across the board. As you can see from my logs, +7.0 actually commanded less boost than +6.0.
MauricioGTI
Brazil
1500 1.0
2000 3.0
2500 3.5
3000 4.5
3500 5.5
4000 6.5
4500 7.5
5000 8.5
5500 8.0
6000 8.0
6500 9.0
7000 8.0
Your DME BT is under a lot of pressure. 20 psi at 4.500rpm and your IAT is not high. I had never seen so much pressure in this range.
GLoBaLReBeL
South Bend, IN
His boost is pretty high for what I've seen for JB4s at 4500 rpm, but he's not getting any ign retard and AFRs and trims look good. Wish I could run that much and not worry :)
bruxwillix
cool learn something new everyday from you all. apparently DME BT is what i thought ECU PSI was. but ECU PSI is JB4 generated. don't think a DME of 20 is danger hi or nothin tho
Sent from my SM-G930P using Tapatalk
MauricioGTI
Brazil
Right buddy. DME BT shows stock boost.
Diggs24
2015 GTI
Yup, DME BT is stock boost. His IATs were around 100F, so not out of the realm of possibility of the ECU requesting 20psi. This is why George recommends going to absolute in the summer. With his additive it is now hitting almost 27psi at peak. That's a lot to ask for the IS20. Maybe for a quick run or 2 I'd do it, but not daily in my opinion. It all really depends on how much risk you are willing to take.
What would be great is another Map that can be selected so you could have a reasonable user adjustable map for daily driving and then a race map. If you had a dedicated tablet or phone in the car hooked up you could select one or the other on the fly, say if a WRX was messing with you then you could flip over to your race map. I don't see map5 as being used.....food for thought BMS!
