GTI Jake
- Charlotte, NC
Which ET Street, R or S/S?
I’m not sure
Do you know the build date? What was the temperature, humidity and elevation when they were installed an how tall was the installer, in cm?I’m not sure
Surely there's an onboard device you can get that corrects for this, correct? If the Hummer H1 can inflate and deflate tires on the move, surely we can create a pump to correct for tidal forces down to the minute, right? Think of the lives we could save at Cars & Coffee if we just got Ford to buy into this for the Mustang!Was the moon's gravitational pull accounted for when they were filled with nitrogen?
Well aren't you guys just fucking hilarious. There's a reason why I'm trying to find out what tires he using because I need to find tires that won't slip on the dyno due to high hp and I doubt my R888R will be able to handle it.Was the moon's gravitational pull accounted for when they were filled with nitrogen?
Maybe on the street but not on a drag strip. Bias ply slicks are for heavier cars.I mean either way it’s very well documented that all drag radials absolutely suck on FWD MQB cars.
Bias ply slicks or 200tw street tires. Hoosier & MT drag radials don’t wrinkle on fwd and perform worse on every surface.
This may be stupid, but would a hub dyno be the solution to this?Well aren't you guys just fucking hilarious. There's a reason why I'm trying to find out what tires he using because I need to find tires that won't slip on the dyno due to high hp and I doubt my R888R will be able to handle it.
No matter, @El_bigote_AJ will just make fun of whatever you end up with.Well aren't you guys just fucking hilarious. There's a reason why I'm trying to find out what tires he using because I need to find tires that won't slip on the dyno due to high hp and I doubt my R888R will be able to handle it.
It would but can't find any around me.This may be stupid, but would a hub dyno be the solution to this?
Lol... Maybe but then again, he doesn't track his car so it doesn't matter what he thinks.No matter, @El_bigote_AJ will just make fun of whatever you end up with.
Where's it documented? Because I'm not finding much on Google. Besides, I've talked to multiple techs at M/T, told them what my car has and they all recommended their drag radials for my car. Told me that the bias-ply are for heavier cars that are north of 3000 lbs so I guess we'll see once I go to the strip.No, at the track drag radials suck on MQB FWD cars. Same 60’ or worse than 200TW & it’s well documented.
Absolutely do NOT waste your money on them. Every 10 second mk7 had bias ply
I mean… you don’t track yours eitherLol... Maybe but then again, he doesn't track his car so it doesn't matter what he thinks.
You had your kid do that for you. Admit it.
Nah man, it was simple in Microsoft Paint.You had your kid do that for you. Admit it.
