iliveoncaffiene
- Cleveland, OH
- 2020 718 GT4
Hey all,
I'm just wondering if anyone has had ANY problems or ANY negative side effects with either this mod or the ECS Bleeder block? Was considering doing the mod when a good, knowledgeable friend of mine advised against it. Thanks.
Did it probably (the DIY job).... 2-3k miles ago? No issues whatsoever - bleeding it was a breeze too, I didn't even use a speed bleeder. I drove at least 1.5k miles on it before I got my clutch upgrade. I was doing this regardless, and I did not have any clutch issues before or after doing the bleeder mod.
I think most people have trouble with bleeding the clutch properly and either drain too much fluid from the hydraulics or they introduce a leak causing pressure loss and stuck clutch pedals.
The only advice I have against it is it may be harder to engage the clutch as smoothly (though surely not impossible).
Also if you save the little yellow piece, it's most likely 100% reversible too if you don't like the quicker engagement.
