RedStarRacer
- Holland, Michigan
Agreed ^ not so much to copy but curious what effect three cars with different setting have for power curve differences!
Current settings are: absolute / fail safe 27 / fol 55 / mods in signature
1500- 16.0
2000- 18.0
2500- 20.0
3000- 21.0
3500- 23.0
4000- 24.0
4500- 23.0
5000- 21.0
5500- 20.0
6000- 19.0
6500- 18.0
7000- 16.0
Straight 92 octane gas. Dyno chart to follow
Any logs on this? I find it hard in my car to hit those high of psi on the back end since the stock boost curve is mirrored.
In for dyno results, really curious to see how it performs. I might have missed it but did you change your parameters since you recently installed the IC?
83 degrees in the shop. The peak numbers are:
303 HP and 341 TQ
There was no timing pull so I could have increased the boost but I'm happy with the HP numbers. The dyno operator was able to spool it up a little sooner but still not 100% pedal until over 3500 RPM.
IAT's got 10 degrees over on this pull.
http://www.datazap.me/u/perry01/log...1-18-25-26-27-28&trim=0&tmin=18.25&tmax=81.51
Why didn't he mash throttle before 3500?
Hi Jerod/Perry. Curious...i am really surprised that the IE was only good for 4 hp.
An intercooler isn't really a big power gain, it's more of a power loss prevention. My IATs were sky high, 127~137 at times. Perry's were way lower. Less heat soak equals consistent power.
Jerod, can you post up your settings for the 299whp run? Also, what octane?
