Hi
you have exactly the same issue as I do. The trims stays flat sometimes at 40 sometimes below and afr rises during acceleration. It scares me to death all the time. How hot is your car, oil, cat? The engine goes lean to stay inside an efficient temperature window for the catalytic converter. If it is too cold or in the heating process it does that I recognized.
George told me not to be too scared about that, because the engine has a safety feature if egt is too hot. It dumps fuel if egt reaches 1050°C. This is independent from trims and also workes if fueling has reached a ceiling.
Your fueling doesn't seem to be maxed out so stay calm I think.
