gs2online
- Chicago IL
When upgrading the rear swat bar is it really necessary to upgrade the end links ???
Curious, since rsb is still on my wish list... What's special about the Moog end links? What advantages do they have over stock? There isn't a lot of info in the link. Cheers!Is peace of mind worth $40 to you? Just buy the Moog, as a preventative measure, at the very least
https://www.rockauto.com/en/parts/moog,K750809,stabilizer+bar+link,7580
They're metal, as opposed to the plastic stock ones- so they won't flex as much and possibly break
Metal, oem-style bearing (means they are less prone to corrosion/grit issues like spherical bearings), wrench flats instead of triple squares, greasable zerk fittings.
Thanks, gents! Makes sense. Adding those to the never-ending wish list, lol.What special is that their not plastic.
Do you use these? If so, how are they for fitment? Need an alignment afterwards? Methinks not.
I have a solid 034 RSB but still stock endlinks, and the rear of the car creaks when going over bumps.
