alper
- cloudy but not too cold
So, I've had VAG cars with the XDS system before (which I turned down to minimum for the track) but this is my first car with the VAQ e-lsd so the question that comes to mind is:
Why would you want the XDS set to anything other than OFF when you have an e-lsd like the VAQ? XDS will only slow you down by braking the inside front wheel (in that sense it's closer to ESP just acting under different conditions), before the VAQ gets the chance to work its magic and actually provide increased grip and higher cornering speeds. (which it has already done in a spectacular fashion)
The way I understand it, for track/fast road use the setting should be:
ESP OFF or Sport and XDS definitely OFF. VAQ will take care of the cornering, much better than any XDS system could (in terms of performance).
On that note, it is worth mentioning that on my MY2017 Clubsport, pressing the ESP button once switches to ESC Sport (no ASR/TCS off message) and if I long-press it, ESP comes back on.
BUT, in the car's soft menu, there is a dedicated ESP selection that has two options: ESP SPORT / ESP OFF. If I manually pick "ESP OFF" then apart from the yellow triangle, a different light lights up on the dash showing ESP OFF permanently. No coding has been done to the car regarding the ESP options. Is it really possible that the ESP can be fully turned off from the car's menu (in 100% stock setup) as that options suggests? Is it the same on standard GTI's? Sounds too good to be true...
