P00B7 CEL
RacingManiac
MI
So I got a CEL light on this past weekend, scanned it with Torque, then cleared it, then it popped back on after. So scanned with VCDS and the detail was:
Address 01: Engine (J623-CXCB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091900122424002F0000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F6D40C476E7B73A09-807A
1 Fault Found:
16987 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [104] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 40378 km
Date: 2016.08.07
Time: 11:54:20
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 255 km/h
Coolant temperature: 104 °C
Intake air temperature: 50 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.617 V
Unlearning counter according OBD: 40
Engine: operating status: ES
Engine temp. management actuator: raw value: 3707
Engine temperature management actuator: stop open: 144
Engine temperature management actuator: after-run stop: 3960
RVC_SP: 260.00 °
RVC_AV: 238.08 °
RVCPWM: -100.000 %
Readiness: 0000 0000
Anyone seen this before? Booked time with the dealer on Friday to check it out. The car doesn't seem to be running any different, and I've had the light go away automatically without me clearing it. And it does not actually come on during driving, always after shutting off the car and then starting after. No warning message or anything. Oil and water temp seems normal. And not spotting telltale sign of the MK6 waterpump failure of dried coolant or low fluid level....
RacingManiac
MI
So dealer checked it and confirmed its thermostat and apparently the whole thermostat/waterpump needs to be replaced under warranty....
Well this is right on schedule as my MK6 as my first waterpump on the MK6 was 25k miles....lol
2slowvw
I show up when i feel like it and delete threads
VA
2022 Tesla Model 3
Better now than outside of warranty. That being said I hope its more of an anomaly than the status quo.
My mk4 Jetta also had water pump problems with the fins breaking though.
kelzzrocka
these water pumps and thermostat housings are different designs than the mk6, good thing that they can be replaced separately . I've had to replace a thermostat on a MK7 golf with 1500 miles on it before.
PLF8593
Philly
19 Alltrack 6MT
The MK7 DEFINITELY doesnt suffer the same waterpump issues as the MK6. Granted, you're experiencing a water pump issue. But that would be the 2nd time i've ever heard anyone say a thing about their waterpumps in the 2 years ive been using this forum.
