greypanter
I see... Engine and trans mouts are easy. I can do the subframe but really don't wanna spend more money than I have too. Cost of wheel alignment and TTY bolts add it quick. Dropping the subframe, press old mounts out and new mounts in shouldn't take more than an hour and half...I haven’t decided what I’m going to do yet. Erwin says you don’t need to drop the subframe if you are able to fit a press and detach the sway bar for clearance. I called a shop to see if they were familiar, but all they would tell me is they charge 4 hours labor. I would pay a shop if the subframe can stay in place.
Right now I’m planning installing the trans and engine mount and seeing how it is with my insert.
Sent from my Pixel XL using Tapatalk
