username205
- GA
Apparently Parts Express' quality control is garbage, so things are on hold until they replace my DSP with one that isn't staticky on 2 of the 4 high-level inputs.
Also I realizied that I have enough equipment laying around to run the tweeters actively, so the passive crossover will be removed from the fronts and my old SMSL SA50 class T amp will added to the setup. The fronts and sub will now be powered by the Pioneer GM-D9705 and the rear speakers will be juiced by the mini class T amp. A single pole double throw relay will be used to switch power to the mini amp.
