Quebster
- Dallas, Tx
Hi all.
I'm about to give up on my DO meth kit. It's been extremely inconsistent. Any and all help would be sincerely appreciated.... I can't seem to figure it out.
Symptoms:
My pump is installed behind the bumper behind the passenger fog light, and I'm using my washer fluid tank for my meth tank, which is behind the driver side fog light. The only reason it's so frustrating is because I have to pull off my bumper to troubleshoot. That's what I get for trying to do a clean/stealthy install.
I plan to call DO about it Monday, I e-mailed them before and they said maybe I have air trapped in the lines. I see on their website for the pump, they say it needs to be "primed" before use. To prime it, they say to disconnect it from the check valve / solenoid and prime the system, then hook it back up.
If that's been the problem all along, I'll be the first to admit I'm an idiot. I just don't understand, why do I need to disconnect the line from the solenoid in order to purge air from the system? Shouldn't the air just push through? I just don't get it. Also I'll have an extra pump for sale
Any help would be great, I'll edit this post as we go.
Symptoms:
- Inconsistent.
- Meth barely dribbles out of line that connects to nozzle when it isn't working right
- When it works, it works amazingly
- I get it working, then seems like when I run out or low on meth, the issue starts again and isn't fixed until I mess with the lines and everything again, even after filling up
- I know when it's not working because I measure my IATs on my phone with a wireless OBDII transmitter
- Also I notice only a little has gone down when I fill it up to the top, whereas when it's working right I can go through a gallon in one track session.
- I have replaced the entire system except controller. Controller lights up according to boost correctly so it looks like it's doing fine
- Replaced pump thinking it was pump, same issue occurs
- Replaced check valve with solenoid (last night) thinking check valve was issue, same issue occurs
- Cleaned all nozzles and meth tank (washer fluid tank)
- Installed in-line filter to make sure it wasn't the pump getting clogged up with junk
- Re-installed DO meth lines
- Re-wired, spliced and crimped electrical lines/connections
