janeirouno
Newbie
- Usa
Having issues and I want to manually check it before my appointment.
Mine has the same issue and sometimes it just beeps nearly nonstop. It also seems to stop when the door is opened. Any idea where the one in the bumper is?
There are 2 KESSY antennas in the car. There is 1 outside the car.
One is just under the front plastic lip of the front cubby in front of the shifter area.
The second is dead center behind the seat of your rear middle seat. You need to pull up the rear of trunk liner where it is tucked under the back of the back seats to see it. The last one is inside the rear bumper, so technically "outside" the car.
There is also an access control module in the steering column and another small module under/behind the glove box. Then you have the two front door handle sensors.
I am also having significant KESSY issues right now. If the car is on, my key randomly stops being recognized if a door on the car is opened and then the warning goes away after a bit.
I am thinking that it's due to the SoundSkin Pro sound deadening material I installed, but the company who makes it says that's not possible. It also seems strange that the doors would cause it to happen given that the key detection sensors are actually inside the vehicle and my key is in the vehicle (in my right pocket) when this is happening.
I just got sound deadening installed and my kessy fault is showing up. My car locks/unlocks with key fob buttons, starts up, and hatch opens. But the door handles are not picking up the key fob. I'm hoping the shop will check it out for me free of charge because it is clearly linked to the install.
Did you guys ever discover if the issue was related to sound deadening materials?
The last post in that thread was 3 years ago.
Seems to me more pragmatic to keep the same question / thread / topic consolidated and updated, ideally having the solutions within as well
