DerHase
- Hampton Roads, VA
- 2019 GTI Rabbit
Just went back and looked.
Interesting that the crazy high coolant also corresponded with the highest avg boost
Just realized I forgot the way you log your boost is different than everyone elses (requires an additional formula to take MAP and subtract ambient air pressure). I left this out the last time I added yours. Essentially it was showing way higher than it should have. You'd be scattering some stuff if you were really running 37psi peak boost
But yes, your second sample while lower speeds overall - there was a bigger spread from min to max speeds obtained. There was higher TPS % and a bit higher average boost as well.
One thing I just thought of is adding a parameter for amount of time spent in boost (over the entire 200 sec snip). Technically if you toodled around the entire track under vacuum 95% of the time, then floored it only on a straight, it'll show as some ridiculously high boost # average due to the way it's filtered - which isn't really a true representation of how often it was really in boost over time. (if EVERYONE logged boost at the MAP sensor then that value could be used without the need to filter out < 0 psi data).
Updated so your last log should be accurate (as far as how it's been getting done goes).
https://drive.google.com/file/d/17OmZvC_tlsmpFnLV45jxSy9Ocyry3ZaX/view
