Diggs24
- de plains! de plains!
- 2015 GTI
I have mentioned these before. You can get them here too...
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html#Mini Cat O2 Simulator Big Daddies Garage
Didn't work.
Could you tell me where is on MAP DP cat? I’m asking because I’m going to install bull x DP with cat in factory place. I got 90 degree mini cat spacer.
Bull x has O2 sensor after cat as well
So, no good with the spacer mini-cat combo.
Going to try just the mini-cat if it will let me put the o2 in without hitting anything.
Stuck lean and slow rich to lean codes today on the way home from work.
Already tried that.
This is the same spacer that I'm using and it worked like a charm.https://www.amazon.com/Vibrant-11619-J-Style-Restrictor-Adjustable/dp/B00AQ7972O
I've been running that with the middle sized insert and a catless setup for about 3k miles so far without a CEL.
I'm installing another into my wife's S3 next weekend with a CTS turbo catted downpipe also using the middle sized insert.
Sent from my SM-G935T using Tapatalk
So minicat, 90deg defouler and vibrant spacer all failed Diggs? Did you try 42DD? Man that's rough.
