Stock Tune w/ Turboback
dmj291
Michigan
Just wondering how many of you guys are running a turboback exhaust on the stock calibration? Not really worried about emissions as it sounds like a spacer should eliminate a CEL. Main concern is leaning out, detonation, etc.
Also, yes I did search... but most of the discussion I found seemed to be around whether you would get a CEL rather than if AFRs were safe. Thanks for the help!
GTI Jake
Charlotte, NC
Won't hurt anything, the ECU can easily compensate for the free flowing exhaust
I'd highly suggest a catted DP tho, if for nothing else to avoid the terrible smell of catless
0bLiViOuS
Orange County
+1 you'll be safe. Some concerns initially were turbine speed but there haven't been any issues. JB essentially is a stock tune and I personally have been jb1/4+DP for almost the entire life of the car (16k+ on that setup)
GTI Jake
Charlotte, NC
The electronic WG controls turbo speed so precisely it's a non issue on our cars.
Shitty turbo balancing on the 2015 cars is what killed turbos and that issue has been for the majority of cars resolved
GhostMetal
Moore, OK
Wasn't there a long chat about not running a dp on a stage 1 tune or it can toast the turbo.
I would strongly caution you against running any hardware the software isn't tuned for. You're injecting a certain amount of "who knows".
Mk7GTl
I ran a catted down-pipe on a stock tune for about 6000 miles and I would occasionally blend e30... ran great with no issues.
GTI Jake
Charlotte, NC
I can confirm that it's a non issue from first hand experience.
Stage 2 is just a more aggressive tune, it's not mismatched like running is38 with a normal stage 1 tune
bdelaney4000
Chester, NH
I've read up a bit on the subject and here's what I learned. In general, on stock tune or stage 1 with very little restriction in the exhaust (straight pipe or close to) there is "potential" for boost creep. This is primarily based on 3 things the waste gate size, duty cycle, and lack of back pressure in the exhaust. Most stage 2 tunes will adjust the duty cycle to compensate for lack of restriction.
www.turbobygarrett.com/turbobygarrett/boost_creep
As someone else said doesn't seem to have been an issue with our cars though as our ECU's adapt very well to changes. However, tuning for your hardware makes sure you're not leaving extra power on the table. :D
_dvorak
Long Island
same here - rev9 catless downpipe, stock everything else. Used it for about 8k miles. No issues whatsoever.
Oldschoolmk7
Yonder
One side benefit of removing the factory O2 housing and cat is reduced underhood temps especially once parked. A 3" catless dp is not going to hold heat like a O2 housing full of ceramic substrate right off the turbo. Potentially could extend turbo bearing life along with less baking of all the plastic pieces in and around the engine bay.
Over 10,000 miles zero issues. Helps engine breathe considerably above 5k rpms. Plus cheap 20-25 whp w/ Rev9.
GTI Jake
Charlotte, NC
And for the best bang for your buck weld a 200 cell high flow cat in a cheap catless dp (like rev 9) for about $100-140 installed. That way you keep the nasty smell down, keep it legal, and still well below $400
bdelaney4000
Chester, NH
Totally agree, my DP is still catted but the cat is further down the exhaust stream (just after the sub-frame hangers) and I ended up wrapping the downpipe from the turbo down to it. Should help keep those under hood temps down. :)
Wastegate13
SoFla
Why. Exhaust systems for this car are expensive, if you aren't going to tune it then it seems like a waste of money and potentially time if you're doing the install yourself.
Oldschoolmk7
Yonder
You can buy a Rev9 full stainless 3" dp for 160 bucks. Real expensive...? Lol.
