My cts sure didn't even though it was sealed. The multi piece design definitely didn't keep heat out. I went closed and felt it almost immediately.
I'll get an open intake and then seal it to the underside of the hood and then post pics. It will work exactly as well as a closed intake.
It didn't seal when I got it so I added weather stripping. I wanted to use your rmethid too, but I took readings with my heat gun and of course all the aluminum was always way hotter than the carbon fiber. Sitting in traffic the car was a dog until I got moving again.
I thought of doing this as well. But I also worried if it did actually heat soak how long would it remain hot if it's insulated on one side. That's why I gave up and went plastic 034 which sucked so now I have the forge Intake.
If you guys have a IC + water-meth you wouldn't have to worry about heat soak and reflective tape and all that... just saying
Just making sure I'm speaking the same language as you...
You are talking about an intercooler and then switching the car over to methanol?
We are talking about doing a cheap high flowing intake and not spending tons of money AND having it still provide cool air. I think everything you suggested is going to add WAAAAAY more cost than even the most expensive intake ever will. To switch to methanol will require some kind of new sensor, probably a new ECU, larger fuel pump, larger injectors, larger fuel rail, larger turbo and so on...and unless you can get an ECU capable of dealing with E85 and gas and combinations of both, then after that the car is going to be limited to just E85 after that. For a track car, that sounds fine. For a DD...not so much.
Did I miss anything? Personally I want more performance, but I also don't want to spend zillions to get it. I'm doing these upgrades on a budget.
Coolingmist Stage 1 $330
JB4 - $430
Intercooler - $700-900
I think I also did bigger injectors and a high flo fuel pump on my last meth/water setup back in 2009. This is ball-park but I agree, this is a shitload more money than guys farting around with their intakes.
You forgot to add an IS38
used $500-$600
new $800-$1000
Looks the husinessIntegrated Engineering. Great finish, sound, and excellent customer service.
used $500-$600
new $800-$1000
