Just adding that the Schroth harnesses are not “approved” by anybody. There are a list of FMVSS requirements which they pick and choose which are applicable to their 4pt harnesses. They leave out the full scale high speed impact testing FYI. Which is prob what you want to know when doing 140mph down a straight.
It’s like “DOT approved brake hoses”. Nobody is fucking testing those to get an “approval”. Things are manufactured to “meet the specifications” which you have to take their word for.
Also the ASM harnesses should not be used with a HANS:
https://www.schrothracing.com/post/anti-submarining-technology
Only exception is the Quickfit Pro.
Factory belts or whole enchilada with cage and 5/6pt harnesses.
I think Schroth & Wiechers have enough first hand experience of designing, testing, & building harnesses & roll cages in motorsports to know what to do that will actually work & save your life.. Most big manufacturers will make a car down to the cheapest price they can & do everything to "just" pass the safety requirements..all to save costs....Making a product to solely meet a certain "specification" doesn't mean its actually safe in the real world....cue the inadequate design/test criteria on flammable exterior cladding which was the main contributing factor in the Grenfell tower fire/disaster..,...the product passed the testing as required ..!!!
I would trust all the above Schroth ASM (anti-submarining) 4 points & Wiechers half cage in a daily & even for track use on a car that is used for fast laps of the local track, or in certain events which would allow it......over here quite a few of the amateur club events would be ok with it..
Over here we get factory road legal cars with half cages & a combination of 4, 5 or 6 point harnesses, & usually the 5 or 6 point harness options are only with bucket seats (i.e. fixed back)..ie Renault & Porsche amongst others (besides Ariel (has 4 points as standard fit), Caterham, Lotus, etc.)....It's a good halfway house better than basic normal car factory set-up...more for a daily...not as good as a full on weld in cage & 6 point harnesses...which then limits the car is solely being a track day car only & not for a daily....
I wouldn't run 5 point harnesses...a central crotch strap is reminiscent of the old Whillans climbing harness...been there, done that!.....
.....& if you fit 6 point harnesses you should only be using a fixed back seat.....& you really need a full cage as you have to have the seat under bar to bolt the two crotch straps to...
Side note:- Although in a different sphere, I know safety systems, & high speed impacts on humans (I used to sell, advise, & specify industrial rope access & mountaineering equipment & sign the certs....so groups such as wind farm builders, tree surgeons, to mountain rescue, to military special ops etc., right through to everyday climbers)
