golfdave
- Scotland (U.K.)
- Mk7 Golf GT Estate
I didn't say it couldn't happen, but that it is an low likelihood scenario in a street car. Number of fires on track/total number of off track excursions is likely v. small. The only fire I have heard of at an event I participated in was a grass fire b/c the car's wheel fell off and it came to rest with the hot exhaust system against the grass which would be a good use of the fire extinguisher in your car if you carry one (I have two in my car). Numbers to me say a fire suit isn't necessary b/c the risk is low to start with of a fire in a street car as well as you can more easily get out of a street car vs. full caged/harness/seat which takes more work, but sure, at some point it can/does happen and wearing a fire suit would be a good thing in those cases...I've at least considered it, you don't see many beyond full track cars at these events. You don't control every risk every day (but you control the ones you think are a risk which will be different than mine), just like you don't drive with a helmet/fire suit on a public road where the risk of a serious crash on a daily basis is greater than doing a weekend track event.
https://www.caranddriver.com/news/a40163966/cars-catching-fire-new-york-times-real-statistics/
I've always had a fire extinguisher at arms reach from the drivers seat in all my cars...When I rolled my car I managed to take the key out of the ignition straight away whilst still hanging upside down when the car was spinning on its roof....
As my door was totally jammed up on the roof/road & the passenger door was partly jammed up against the grass embankment & we had to get out using the passenger door...but the passenger had to get out first & needed a hand...in those minutes my greatest fear was a fire starting, be it by fluids on a hot metal item, or by an electrical short/spark...I've seen it happen...
I'd say to the OP & anyone that if you're starting track stuff, you should at least have a fire extinguisher & seatbelt belt cutter/window breaker device...(even as everyday car items)
Then driving gloves for more grip on the steering wheel & maybe race/club boots, or thin soled lace up loafers/deck shoes, for more feel of the pedals & so your feet don't get caught up by the shoe on the pedal next-door, & clothing that is comfy & allows good movement of legs & arms..
Then look at helmets, but if you wear a helmet you really should have a neck support or HANS type device to control the extra mass/weight you have placed on your neck which place's more strain on it in an accident let alone normal track driving side forces.
Then & only then look at cages & different seats & harnesses...as you will need to get helmets as soon as you fit cages which may be too close to your head....& at this stage maybe look at suits....
The only other thing is any events you enter, if they specify certain stuff, then you have no option but to fit it!...& if thats cages/multipoint harnesses, they may specify safety gear such as external battery isolators/shut-offs also!...
P.S...
This is the lower south west area of the UK fire service quote:-"Each year we help around 650 people whose vehicle has caught fire. Fires are most likely to start when you're driving which can be a terrifying experience"....
https://www.dsfire.gov.uk/safety/on-the-road/car-and-vehicle-fires
