PDC Retrofit Question
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
I've been following this thread since last September when I started planning the installation of the Park Assist module/sensors into my MK7 2017 NAR Golf R. I already have the eight (8) Park Pilot sensors installed from the factory and went ahead and ordered the kit from Carsystem last year for the four (4) Park Assist and now have everything prepped for installation. I have all of the installation tools and have the pinouts as directed from Carsystems, which I've validated several times. The only remaining installing step I haven't quite sorted is where to best tap +12V power. I was thinking of tapping the incoming power to the existing Park Pilot module but I haven't taken that plug apart yet to figure out how it would all fit together. I also have done all of my retrofits without permanently altering the original wiring harnesses and have used OEM pins/connectors. I was hoping to continue that. I really appreciate all of the work you guys have gone through documenting your installation process. It's been a big help understanding the process.
Cuzoe
@Kushdaiin Why do you need another source for 12V power? The sensors get power from the parking module. They don't get a separate source for 12V power. Got a link to the carsystems kit you picked up? I have an idea of what is needed to go from 8 sensor to 12 but want to make sure I'm missing anything before throwing out any advice.
Assuming it's this one... https://www.carsystems.eu/vw-golf-7-5g0-park-assist-pla-upgrade-set,id1462.html
If yes, you don't need any additional power. You'll just be adding the following wiring:
2 New Front Sensors > PLA Module (18 pin plug, T18k)
2 New Rear Sensors > PLA Module (26 pin plug, T26i)
Center Console Switch (existing plug) > Parking Module (26 pin plug)... 2 wires, the other wires will already be there for your current switch
Of course, you'll replace the module (and code it) and replace the set of switches on the right side of the shifter. Each sensor (both your current 8 and the 4 new) has two wires. One goes straight to the parking module. The other wire is the return (ground), which is shared between all 8 (or 12) sensors and it goes back to the PLA module T18k. I assume this add on kit will have you bring all the new sensor wiring back to the PLA module. Then splice your 4 new sensor return lines into the wire at PLA Module T18k pin 10.
Edit: Losing my mind apparently, so editing this post. I'm not sure where car systems intends for you to get 12V from. But if each of the four sensor harnesses has all three wires going all the way back to the module... you can pick up power at the same wire that provides it to the module, pin 18 of the 26 pin connector.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
@Cuzoe That’s the kit that I bought. The funny thing is the wiring loom to the front and rear sensors have both +12V and ground coming off of the sensors (black/red). The rear wiring loom the connects to a another extension loom back to the parking module. The extension loom is where the power/ground are left unpinned. See pictures below.
Those unpinned power/ground wires is why I was asking the question as they come off of the extension loom. Your logic makes sense, that power should come from the new module as I already have the park pilot module. But possibly it doesn’t?
Cuzoe
@Kushdaiin and those connectors fit the sensors? From what I recall the sensors only have 2 pins.
Edit: Found some (not great) pictures and it does appear there are 3 pins. Somewhere several pages back I posted wiring diagrams.
***I will edit my previous post, I'm losing my mind obviously, haha. There are three pins on each connector***
Can you post pictures of the sensors they sent you? Including part numbers and a picture inside the connector.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
Thanks @Cuzoe. That's what I was thinking. Thankfully they've spliced the looms so that it's only two (2) power and two (2) ground wires from both the front and the rear sensor sets. I'll most likely go forward with using dovetailed pins and a harness to avoid directly splicing into the factory harness. Just to verify what I've picked up so far, it sounds like the rear harness runs along the left-hand side of the vehicle for most of the aftermarket harnesses vs. the right hand side in the OEM wiring diagrams (i'll check length before tearing into the car)? And, the best way through to the front bumper cover is the through the existing grommet through the firewall, despite the congestion in that area? I'm really looking forward to this mod. Thanks again.
Cuzoe
That is correct... OEM routing is down the right side. When I did the retrofit (coming from no sensors) I re-pinned the retrofit harness because I was going down the right side of the vehicle, as per OEM routing.
Also correct about the grommet in the firewall. While I'm sure there is another way, I don't know what it is, haha. Pull your airbox, battery, and battery tray and you'll be able to see the engine bay side clearly.
JettiGLI
LA
I updated the parking sensor module to have maneuver braking, everything works perfect for the exception I lost my rear buzzer, now both the rear and front parking beeps come from the front buzzer.
Any repining has to be done?
Fraysa
Israel
2016 MK7 1.4TSI
Just throwing an update here.
I helped my friend with an Audi A3 8P (2011) to retrofit PDC. He used the genuine tools for his era (VAS 6614) with the appropriate holders/cutting tool which state 18mm and it came out perfect.
Found an official document regarding the MK7 saying it has to be 18.6mm. So for anyone seeing this in the future... to get flush sensors you'd need 18.6mm, not 18mm.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
I just started on the installation of the PLA sensors on my 2017 Golf R which already has the park pilot sensors. As noted above, I bought the system off carsystems.eu. Turns on the wiring loom to for the rear park assist sensors (i.e. parallel park sensors) was more than long enough to run down the right side of the vehicle in line with the OEM routing. I was also able to get the pins through the existing grommet without cutting it. Rear bumper was removed and I was able to identify the crosshairs for the sensors but the front bumper does not appear to have any crosshairs for the parallel park sensors. I'm thinking at this point I'm going to have to make a template based upon my 2017 GSW which has the park assist sensors. Going to add a little bit of time to the install but seems like the easiest route. Anybody have any experience doing something like that? Next up will be wiring the front sensors. I always hate having to take out the battery, but it's got to be done.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
Well dang it. I went to go test the PLA 3.0 system today and after going through the Coding from XaGiCO and adjusting it a bit as I've seen that PLA coding is different from PLA 2.0, I'm getting a number of faults associated with the module swap and the additional four sensors. I did follow a suggestion for PLA 3.0 to Code byte 24 on the ABS module (03). Since no bits show up in VCDS anymore for the ABS module, I found this coding for bit 24 (B8). Any help would be appreciated. I did take the battery out for the installation and have yet to drive the car as I still have the bumpers off the car but plugged in. Thanks!
Code:
Sunday,28,August,2022,09:45:56:28357
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWWF7AU1HW149710   License Plate:
Mileage: 112240km-69742mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 65 75 A5 A9
VIN: WVWWF7AU1HW149710   Mileage: 112240km-69742miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: 4788C367
   Coding: 091900122446000E3004
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48C95FE64235171B47F-801C
   VINID: 9E69E75874650589C11091C100131EE2CF
1 Fault Found:
17178 - Databus
          U1123 00 [039] - Received Error Message
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:15
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 20 °C
                    Intake air temperature: 22 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 11.894 V
                    Unlearning counter according OBD: 40
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
                    Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
                    Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
                    Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63256000008869
   Coding: 01FA6BA154240975457E030140C36980D62A90A2C00296371440508440A8430000000012121212B835351919323200
   Shop #: WSC 61740 001 104857
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
   VCID: 78A9EF267255A79BF7F-802C
1 Fault Found:
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:14
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0424013287
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002019
   ROD: EV_KessyHellaMQBAB_002.rod
   VCID: 3B23302A03E34C83DAD-806E
No fault code found.
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 0002000410010001010500401211142A
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D87CE720D171233149-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061632000280
   Coding: 00010E46C041A2F169E44000091C07201800000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04518BD63E9DF37BEB7-8050
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    161027  043 0551
   Serial number:         161112142417
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S6Y16M11D23H16M26S22
   Coding: 06A8DD
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319037
   Coding: 0270167941
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF7282B16FD6D3101-8004
20 Faults Found:
1080340 - Parking Aid Speaker
          B107C 14 [009] - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 133
                    Date: 2000.00.00
                    Time: 00:00:00
1111316 - Speaker for Front Parking Aid
          B10F5 14 [008] - Open or Short to Ground
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 173
                    Date: 2000.00.00
                    Time: 00:00:00
1113619 - Parallel Parking Assistance Indicator Lamp
          B10FE 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
1113875 - Parking Aid Indicator Lamp
          B10FF 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
13636352 - Control module not coded
          U1013 00 [008] - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 173
13638912 - Databus
          U1121 00 [008] - Missing Message
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
13638913 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
10487040 - invalid data record
          B2005 00 [008] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 173
12648466 - Databus
          [Motorsteuergerät - Motor_14 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 173
                    Date: 2000.00.00
                    Time: 00:00:00
12656917 - Databus
          [Bremsensteuergerät - ESP_05 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
12656918 - Databus
          [Bremsensteuergerät - ESP_19 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
12656920 - Databus
          [Bremsensteuergerät - ESP_21 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
12656921 - Databus
          [Bremsensteuergerät - ESP_24 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 173
                    Date: 2000.00.00
                    Time: 00:00:00
13632273 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Anhängererkennung-J345 - Gateway_72.Anhaenger_01_alt - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:14
13638914 - Databus
          [Steuergerät für Lenkhilfe-J500 - LWI_01 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:14
13637426 - Databus
          U1123 00 [009] - Received Error Message
          [ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:15
13679386 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:13
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 173
                    Date: 2000.00.00
                    Time: 00:00:00
12648468 - Databus
          [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Component: ACC BOSCH MQB H10 0620
   Coding: 2D0060C151FFC428949C810510301600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002005
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 3C21333606ED4BBBD37-8068
4 Faults Found:
2055 - Databus
          U1122 00 [009] - Implausible Message
          [FAULT_ALP_STEERINGWHEEL_INIT]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:16
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 11.8 V
                    Velocity_vehicle_reference: 0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
                    Status_ACC_System: ACC_irreversible error
0803 - Databus
          [FAULT_BV1_FEHLER]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:15
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:15
                    Status_ACC_System: ACC_StandBy
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:15
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 B    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0121
   Serial number: 14101641350035
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292F2632D5679B37F-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 J    HW: 5Q0 959 655 J
   Component: AirbagVW20    010 0830
   Serial number: 003GCR06L212
   Coding: 8CCCFC00000000005000001AC24800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 47CB5CDA4F2B18634E5-8012
   Seat occupied recognition passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 B    HW: 4M0 959 339 B
   Component: BF-Gewichtss.  H13 0022
   Serial number: IBH000000000005ZWOU0
   Coding: 30324E
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: -----------    HW: 480 002 411 16
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000B5805E02H
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 3 - Part No SW: -----------    HW: 480 001 811 16
   Component: SideSensor_Pf  001 0887
   Serial number: 35800000000590B00F1E
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
   Component: SideSensor_Dr  000 6149
   Serial number: 3510001B522F976174F8
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 811 16
   Component: SideSensor_Pr  000 6149
   Serial number: 3520001B523204B3A56U
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 411 16
   Component: FrontSensor_D  001 6149
   Serial number: 3550002C122E8E15611$
   Coding: 2D2D2D
   Crash sensor for front airbag: front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 711 16
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C323B3B54C10$
   Coding: 2D2D2D
1 Fault Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 10:08:23
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0140
   Revision: --------    Serial number: 22111604221391
   Coding: 0C00
   ASAM Dataset: EV_SMLSKLOMQB 020002
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 094F9AE219BFAE13981-805C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 076D4092FE8CCF4402847F2F4401000800000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2A0D056EFC79C50BB1B-807E
2 Faults Found:
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:16
16776996 - Databus
          [FCW_01 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:16
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 11111610802901
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   GVL: 01DC3C100000060040CC900080004C0000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1F336466D8BBB937-8028
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160003055210106456
   Coding: 34FFFF
3 Faults Found:
131595 - Tire Pressure Monitoring Module
          U0127 00 [008] - No Communications
          [Timeout Knoten 0x0B / 65 - Steuergerät für Reifendrucküberwachung]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 29
                    Reset counter: 216
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 10:24:27
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 216
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 10:24:26
                    Terminal 15: OFF
15360512 - Component Protection
          U1101 00 [009] - Active
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:17
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00002.11.16
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4ACD65EE5C39E50B51B-801E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 16000196591010
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311B162EBD83FB1B7-8060
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Part No SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
   Component: HRE_Master    H12 0071
   Serial number: 0422386557
   Coding: 02011103
   ASAM Dataset: EV_HREntryHella 001028
   ROD: EV_HREntryHella_VW37.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 B    HW: 5Q0 907 685 B
   Component: HRE_Slave  H12 0071
   Serial number: 0422370730
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 111116EKB02623
   Coding: 003F1320D000040000000000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D348CA7B13344392D-8016
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000012329432
   Coding: 111000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Coding: 9102
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D352E0CD9758BC1B-806E
1 Fault Found:
16272 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 176
                    Date: 2000.00.00
                    Time: 00:00:00
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.25 V
                    Temperature: 26.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Freeze frame conditions: 5F
                    uAdSensI_U1V2Filtered_gdu16: 1.20 V
                    uAdSensI_U5VFiltered_xdu16: 0.00000 V
                    uioUdNotFilt_xdu16: 12.56 V
                    uAdSensI_SwitchedKl30_xdu16: 12.56 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_KMN_RACKPOS_SET: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_WHLSPDPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H30 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA02V197
   Coding: 1200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
2 Faults Found:
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:13
                    Voltage terminal 30: 12.1 V
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:13
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 121116EKC08275
   Coding: 003F1320DE00040000800000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DD4DCE64093D4B99B-8016
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000012443399
   Coding: 091000
1 Fault Found:
65799 - Door Warning / Entry Lighting
          B1775 01 [008] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 10:35:18
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 022202107F000400
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40D947C66A052F5B8FF-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 900000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 900000
1 Fault Found:
13705995 - Databus
          [Kamera_Status: Fehlerwert im Signal Kamera_FDD_Funktionsstatus]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:45
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 5NA 035 047 C    HW: 5NA 035 047
   Component: MU-H-NS-US    H51 1126
   Serial number: P065J0GB010073
   Coding: 027310020000000051220002001808201F0007F401708405DE
   Shop #: WSC 00256 168 00001
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606 C    HW: 5G6 919 606 C
   Component: ABT_High-2  280 9304
   Serial number: VWZ6ZMY3005349
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 806 NG    HW: -----------
   Component: NAR 2021  --- 0081
   Serial number: --------------------
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 3011
6 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:25
                    Status_Software_Version_Management-module_name: MDUV669/Main
15360256 - Component Protection
          [Anti-theft protection - component protection active (0xEA6100)]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:20
2571 - Navigation System
          B126C F2 [008] - Navigation Database not Enabled
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Voltage terminal 30: 12.4 V
0020 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 10:08:55
                    Voltage terminal 30: 12.3 V
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
          [USB - communication error]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:20
                    Interface for external media: status-Status: Open circuit
7225 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Range data (0x39) - function restriction due to communication error - BapErr_retry not successful]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112241 km
                    Date: 2022.08.26
                    Time: 09:55:22
                    BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (J502)       Labels: 3AA-907-273.clb
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000257464
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5QE 035 285 A    HW: 5QE 035 285 A
   Component: OCULowMQBUS   007 0570
   Coding: 02730002C2821A017F1E06020000
   ASAM Dataset: EV_OCULowMQB 001006
   ROD: EV_OCULowMQB.rod
1 Fault Found:
9457171 - Audio signal output 1
          B14F1 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 22111612K23470
   Coding: 0003070000000201002213548040890094000E120040
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
2 Faults Found:
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:15
                    Outside temperature: 21.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2.8 s
                    mid: 00 28
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:42:16
                    System run time: 3.3 s
                    mid: 02 E0
                    Status of camera: System malfunction
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 161103202521
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 2F3B147AC79BA023665-807A
End----(Elapsed Time: 02:09, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Sunday,28,August,2022,10:22:16:28357
www.Ross-Tech.com
          5F 65 75 A5 A9
15-Airbags -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
75-Telematics -- Status: OK 0000
   Coding: 091900322446000E3004
1 Fault Found:
17178 - Databus
          U1123 00 [047] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:07:15
                    Coolant temperature: 41 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.207 V
   Coding: 01FA6BA154240975457E030140C36980D62A90A2C00296371440507A40A8430000000012121212B835351919323200
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:54:21
8307 - Databus
          [FCAN: PLA_Status_PLA_ESP signal is invalid]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:54:21
8311 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: Damper not coded but Fahrwerk_01 message received]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:54:21
16385 - TPMS Display
          C1146 F2 [137] - EEPROM Malfunction
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
   Coding: 032C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 06A8DD
   Coding: 0271167901
   Shop #: WSC 12345 123 12345
4 Faults Found:
13632273 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:13:23
13637426 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:13:23
13679386 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:13:22
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:15:25
4 Faults Found:
2055 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
                    Control Module temperature: 30 °C
0803 - Databus
          [FAULT_BV1_FEHLER]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
2101 - Databus
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
2068 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
   Coding: 30324E
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 0C00
   Coding: 076D4092FE9CCF4402847F2F4400000800000000
3 Faults Found:
13636608 - Control Module Incorrectly Coded
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:52:18
16776980 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:58:58
16776996 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
   Generator:
   Coding: 34FFFF
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:06:38
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
                    Terminal 15: On
   Coding: 0001
   Coding: 02011103
   Coding: 020111
1 Fault Found:
338048 - Databus
          [Parkhilfe_01::PH_Tongeber_H_verfuegbar]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:53:19
   Coding: 111000
   Coding: 9302
1 Fault Found:
16275 - Steering Angle Sensor
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:15
                    Motor status: 00
                    System status: Waiting for start request
                    Supply voltage: 11.75 V
                    Temperature: 29.0 °C
                    KFC: 3F
                    KFA: 00 93
                    uioUdNotFilt_xdu16: 11.91 V
                    uAdSensI_SwitchedKl30_xdu16: 11.91 V
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_UNDERVOLT: not activated
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:04:48
                    Voltage terminal 30: 11.8 V
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:04:48
   Coding: 091000
   Coding: 900000
   Coding: 900000
1 Fault Found:
13705995 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:15
   Data carrier:
3 Faults Found:
          B201A 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:26
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:19
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:21
2 Faults Found:
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:02:50
                    Control Module temperature: 43 °C
                    Outside temperature: 22.0 °C
                    System run time: 1239.0 s
                    Voltage terminal 15: 11.7 V
                    mid: 00 28
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:02:51
                    System run time: 1239.5 s
                    mid: 02 E0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Sunday,28,August,2022,10:48:19:28357
www.Ross-Tech.com
          5F 65 75 A5 A9
01-Engine -- Status: OK 0000
   Coding: 01FA6BA154240975457E030140C36980D62A90A2C0029637B840507A40A8430000000012121212B835351919323200
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:44:08
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:44:08
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:44:08
8370 - Databus
          [FCAN: ARA_02 is not received]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:44:15
8377 - Databus
          [FCAN: ARA_Status_01 not received]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:44:08
   Coding: 032C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 06A8DD
   Coding: 0371161101
4 Faults Found:
13632273 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:13:23
13637426 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:13:23
13679386 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:13:22
13688835 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:15:25
5 Faults Found:
2055 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
0803 - Databus
          [FAULT_BV1_FEHLER]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
2111 - Databus
          U1123 00 [008] - Received Error Message
          [FAULT_ESP_CONS_ACC]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:39:26
                    Control Module temperature: 37 °C
2101 - Databus
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
2068 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
   Coding: 30324E
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 0C00
3 Faults Found:
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:52:18
16776980 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:58:58
16776996 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
   Generator:
   Coding: 34FFFF
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 216
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:06:38
                    Terminal 15: OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:16
                    Terminal 15: On
   Coding: 0001
   Coding: 02011103
   Coding: 020111
1 Fault Found:
338048 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:53:19
   Coding: 111000
   Coding: 9302
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:15
                    Motor status: 00
                    KFC: 3F
                    KFA: 00 93
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:04:48
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:04:48
   Coding: 091000
   Coding: 900000
   Coding: 900000
1 Fault Found:
13705995 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:15
   Data carrier:
4 Faults Found:
          B201A 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:26
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:19
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:36:49
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 09:46:21
2 Faults Found:
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:02:50
                    mid: 00 28
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 176
                    Mileage: 112240 km
                    Date: 2022.08.28
                    Time: 10:02:51
                    mid: 02 E0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:03, VBatt start/end: 11.8V/11.8V. VIgn 0.0V)------
Cuzoe
You could just turn the wheel lock to lock with the ignition on and clear the battery related faults I think. And then maybe do a clear all faults in all modules just to see what comes back.
But I see not coded and invalid data record faults in the PLA module. Looks like it needs parameterization. Assuming you are not in a golf R Make sure you do a data set for cars without electronic parking brake. Otherwise you'll still have that remaining fault. That's the only fault in my auto-scan right now.
And I've got PLA 2.0 but with 12 sensors. I suspect you can pop in your old module and code it for the parking assist if you just want to make sure your new sensors wiring and everything is good. That'll let you reinstall your bumpers while you work on getting the data set for the PLA 3.
I have a PLA 3 module sitting in my garage. According to the eBay listing it was removed from a golf so I'm hoping I don't have to worry about data set issues. I've yet to plug it in and try to get it set up in the car, laziness.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
Thanks @Cuzoe. I am in a Golf R with an electronic parking brake, so I suppose I'll need a dataset with an electronic parking brake. Kind of disappointed that I'm having problems with the module because I got the system off carsystems.eu. I'll send them an email tonight and see what kind of response I get. I'll be installing the front bumper tomorrow as I got to the sensor brackets late in the day and will need to modify the plastic fender frame to make the sensors fit. I spent most of my day today fretting over the location of the front sensor brackets as my bumper didn't have any cross hairs. I think I did a decent job considering.
I'm also hoping that my other module from Doki Auto will work. However, I tried plugging that into my SEL GSW to see if I could upgrade it from PLA 2.0 to 3.0 and it got a little upset (probably because I didn't do any additional coding). After I get the bumper on tomorrow, I'll go for a drive and see what errors come back. You're right though, I could plug in the old module and see how that shakes out if all else fails. I might have to return all the coding back but that's easy enough to do. Thanks for help! Oh and I don't have VCP or ODIS to load datasets. If worse comes to worse, I have a shop about an hour from me that might be able to load a proper dataset.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
I was able to get the PLA 3.0 module/sensors installed on my Golf R and working thanks to the Ross-Tech forums. This forum has also been a lot of help. I was wondering if anyone who has installed the PLA 3.0 system has had the same experience I currently have. In my 2017 GSW with PLA 2.0, I can change parking modes by pressing the PLA button a second time, however with the PLA 3.0 system I just installed on the 2017 Golf R, pressing the PLA button a second time only cancels the operation and does not cycle through the parking modes as described below. Has anyone experienced this? Coding is currently 0271167801. Thanks!
xabhax
15 GTI
This is anecdotal but I had tried the 5qa module and could never get it to work right. I have the 5q0919298k and it works like you describe.
Kushdaiin
Connecticut
MK7 R, MK7 GSW SEL
I appreciate that. At least someone else is having the same experience. Curious that you couldn't get the 5QA module working. I'm debating updating my GSW to PLA 3.0 but I may hold off as I like being able to cycle the parking modes.
