- Tennessee USA
Here is some info on a pre filter cabin filter one can install.
Forum Member Sabo has more info on his build thread.
Info below and link at bottom.
Easy mod.
I first learned of this mod from a forum member who owned a Light blue Golf Wagon. I do not recall his forum name but I know he was outside the USA. Most of my info I have is from Forum Member "SABO" who hooked me up with a new Pre Filter Housing and 1 filter. This mod is not that hard to do but might be a big help in keeping the cabin filter fresh and reduce any bad smells long term in the car. What the pre filter collects, bugs, pollen, etc. will be more outside the car and might help keep the smell out also. This snorkel housing is located under the cowl, bottom of the windshield on the passenger side.
Giving "Sabo" the credit here is a link to his build page where he has listed the part info and link to purchase.
Not a hard or costly not.
Filter housing is under $20.
Filters are around $4.
Worth a test.
Old Housing
Your cars vibrator.
AC intake opening - something to clean.
The pre-filter is within 4 inches of the main cabin filter.
Filter housing compare.
Temperature Sensor - Hole
The new housing has a larger hole. Had to help this out.
Use two way auto tape to make for a tighter fit. Tape does not hold well to the plastic but friction fit should hold. Will keep an eye on it. You will need to secure this more when you move to new housing.
New housing bolted in.
Filter in place.
The filter is not water proof. I put a drop of water on it and it soaked it right up. If we could find this filter made in the same material as a Shop Vac washable filter it would be great.
https://r.tapatalk.com/shareLink?ur...hare_fid=112413&share_type=t&share_pid=360374
Easy mod.
Worth a test.
Old Housing
Your cars vibrator.
Filter in place.
