0bLiViOuS
- Orange County
I was looking at the new A4 last night and it's got a 7 speed so I'm curious which one it has at well.
No. It's not. VW opened large factory in China and DQ380 for now only made there. So Chinese GTI doesn't have DQ250, only DQ380Our DSG is made in China?
I don't read chinese but I can't find any information showing that the Chinese market GTI gets a DQ380. As far as I know all DSG's in MQB cars rift now are the DQ250. The TTRS will get a 7 speed again.
The DQ380 is rated for 20 lbs. ft less than the DQ250, perhaps the DQ381 can handle more than that?
http://vw.faw-vw.com/public/downloads/GTI.pdf
Check out page #17. It's clearly stated which transmission it is.
DQ250: Torque Maximum 350 Nm (depending on engine)
Wikipedia is wrong about it. It's rated 250 Nm.
Check our service manual of VW itself http://at-manuals.com/wp-content/uploads/2016/manuals/02E DQ200 DQ250 manual.pdf
DQ380: Rated to 380 Nm (maximum 420 Nm).
So it's 70Nm more, not 20 lbs.ft. less.
DQ500: Rated 500 Nm (maximum 600Nm).
I don't read Chinese too, but you can see it's written DQ380 350Nm...I clearly said I don't read Chinese.
Not sure what you are exactly saying here? First you say it's 350 Nm (which appears in your 13 year old service training brochure) then say it's 250 Nm?
Is there a possibility of there being updated specs?
Because the Golf R stock makes 380 Nm of torque. So I guess every Golf R DSG is about to blow up?
There is maximum and rated torque. Rated torque is basically in the name already. Maximum I've stated above. If you know better source of info - let me know. I assume that Golf R uses increased friction plates in the clutch. Is it same in other cars - I don't know. I'm quite new to MQB platform, most of my knowledge is about DCT470 dual clutch trans. So I could be mistaken. Correct me if I'm wrong with better sources.
DQ380 is a 2 wheel drive version of the DQ500, with redesigned clutches. the circuit board and the gears remain the same.
There's a history lesson why Chinese and Singapore GTIs have DQ380. I emailed someone who worked in VW China and here's what he said.
DQ200 and DQ250 are those used widely years ago. DQ200 is widely used on small engines such as 1.4T and 1.8T, DQ 250 is mainly used on larger engines like those 2.0Ts on Passat, which is not a volume seller in China. Since import taxes are much higher, VW built a production line in China for DQ200 and imported the DQ250.
Later on, the DQ200 has a major failure occurred in China market. Then VW chooses to pick another DCT to be manufactured in China. They picked the 7-speed DQ500 (DQ500 is widely used on SUVs) and redesigned the 7-speed DQ380.
DQ380 is widely used on most of VW vehicles today in China including Jetta and Passat. So the 7th gen GTI just uses it as well. the downside is maybe some of the popular tunes couldn't be used. another downside is VAQ couldn't be compatible with DQ380, all the GTIs in China don't get VAQ.
later, DQ380 was redesigned again to be the DQ381,which is manufactured in Europe now.
