Yes I have the jbale harness with single rear fog.You have the JBale harness? Curious to try considering I want to maintain use of the rear fog.
I am going to install these today!
Most likely you are having an issue with the wiring to Pin5 Outer Left. Left and right brake light use the same light channel, so no coding issue.
Additional question: Without parking lights on do the whole tails light up once you apply the brakes? If you want to get rid of it try the following coding change:
“Lichtfunktion B27” from “Bremslicht” to “nicht aktiv” = not active.
Please let me know how they are, I’m so close to pulling the trigger.
Intsalled the ali ver taillights
under my observation, this taillights should be direct plug and play to mk7 NA too, just the amber signal won't work if you don't use the harnesses
Works perfectly but the very end angle of both outer tail are broken, contacting seller for replacement
https://www.youtube.com/watch?v=9uoAX4LcdNo
I will post more pictures on my car journal later
Thanks JBale for making this one-off(mk7.5 to mk7) harness!
One more thing:
I am having trouble on putting back the biggest hatch trim. The left side fits but the right hand side just couldn't slip in
Looking for hacks or tips
Thanks
Refresh ratesWhy do they appear to have flicker in the video?
If it's the same metal clips as the upper hatch trim piece, you can easily bend/flatten them, then you're screwed and need replacement clips. I took 1 or 2 of them from the lower spare tire trim (since i had left it out for now to cut it out later as part of the spare tire mod) when i botched the reinstall of the upper hatch trim.
Refresh rates
It's the plastic part not the clips, I fitted the left side but the right side couldn't slip inside.
