LachlanGordon
- Sydney, Australia
I have a question, I have a row European built gti with the bulbed tails (non led), I've ordered the tail lights and the adapter harness, do I need anything else to get the lights to work?
No, but which harness did you orderI have a question, I have a row European built gti with the bulbed tails (non led), I've ordered the tail lights and the adapter harness, do I need anything else to get the lights to work?
Not sure what you're talking about. Links or pics?
Sent from my SAMSUNG-SM-G935A using Tapatalk
You will need the audiamant adapter.Please help me understand. I got lost with entire process of installing FL taillights. I have mk7 led taillights in the car with extra harness connected into bcm. As of now my car is wired and coded same way as row versions.
There is mk7.5 taillights set you can purchase from vw in Europe for 519 eur. And according to the manual (see attachment) I would have to add extra wire to bcm and code. Will this setup spare me from buying Audiamant harness in addition. http://cloud.tapatalk.com/s/5971c2fedad34/904_DEBA_5G1052200C_ENG_002.pdf
Different connectors?Yes, getting the kit through VW and using their wiring method would spare you the need of buying the audiamant adapters.
InterestingIn manual there are pn for connectors to swap
Well i have the oem wiring harness sitting around so i could of turned my nar into full row wiring and had a super clean oem swap but oh wellYes it is. Audiamant harness is half price of entire taillights set. I guess it was good idea to wire car same as row while led retrofit year ago.
Flapje said:You need to change the CHLH coding, to make the inner taillights light up as well..
'Leuchte27NSL RC6-Lichtfunktion B 27' change from 'not active' to 'Parklicht links (beidseitiges Parklicht aktiviert li & re)'
I have a 2016 GTI-S with the OEM LED taillights and BEC harness.
I'd like to get sequential amber "flowing" turn signals from my existing retrofit installation.
What do I buy or do I remove everything and buy all new stuff and sell the old stuff?
I've attempted to digest the current 74 pages of information, and 1/2 way through I'm a bit confused and lost.
MAYBE a new thread needs to be started to have a fresh, clean starting point for the conversion and not dwell on of the previous unknowns.
OR, vey simply have a chart: If you have this, you need that, if you want this result, you need these, etc. and so forth.
Is there a solution or is all of this trial and error and a work in progress?
