This post makes little to no sense. The audiamant solution is 100% functional tails with dynamic.
Let me elaborate. I own a Golf SportWagen which is the NAR version of the Golf Variant. Like the rest of the Golf 7 line, the Variant also received LED taillights with the 2018 facelift---this is in fact the very first time the Golf 7 Variant has LED tails available. Over in the Golf 7 SportWagen forum at vortex, we have a thread discussing the new facelift tails, and are trying to figure out a retrofit solution. The housing fits, but we need to figure out the connectors since VW changed the connector on the inner tails. (
See this post).
The facelift Golf 7 has two versions of LED tails---low line and high line. Low line is standard and has static blinkers. High line has dynamic blinkers. The tails for the Variant are similar to the Golf 7 low line tails, but with some physical differences in shape due to the shape of the rear hatch on the Variant. However, it appears that all of these tail light housings (Golf 7 low/high, and Golf 7 variant) use the same connector on the inner tails. Hence, my question about the male plug on the Audiamant adapter.
In terms of wiring, retrofitting the Variant will be much simpler, since the NAR version has all the necessary wires (except rear fog). So all we need to do is to transfer the pins from our current connector housing to the new connector housing.
