Can I place a hand jack or jackstands @ these 4 points in red where professional lift pads are placed?
Photo by whispaz
Photo by whispaz
So just to clarify, when jacking up I've simply been using the included scissor jack without a hockey puck. Should I throw away my car and get a new one or is it OK to skip the puck?
No, there is a pinch weld back there too. That's the proper jacking point (unless you have the pads installed, but then why would you have asked about the rear?). You can then drop the car down and lay the stand on the spot I pictured from Kevin's thread.
On the pinch welds
Marked with a little notch/arrow on the rocker panel
What is that spot that is pictured there? Hard to get context from that photo. Is that a frame rail? It's safe to place a jack stand there, even without any jack pads installed?
Is that a reply to me? I don't like jacking the car on the pinch welds, so not sure about using them for the axle stands, I find them scary thin
That's what they are there for though and where a shop/dealer would put the lift pads at on a 2 post lift
I use a hockey puck on the jack too, never had an issue.
If I put a jack stand under the pinch weld, I usually put a towel over the stand to protect the body/lift point too (so it's not metal on metal)
How long did it take you to install the headlights?Finally got the GTI up in the air for the first time today to install my new Helix headlights from OPD. I ended up going for the red striped ones, which meant I needed a new grille to get the alignment right with the stripe. Deutsche Auto Parts happens to be local to me, and Paul was in the shop when I went by to pick up the grille. I explained what I had (two jack stands and a floor jack) and his suggestion was to jack it up from the rear, which would require a little extra height.
So that's exactly what I did. I jacked up one side with the floor jack from the rear, then placed the jack stand under the front pinch weld with a shop towel in between. Repeated for the opposite side.
This seems to have worked great. It does require a little extra height to get the jack stand under the front, but it all seemed stable. No damage to the pinch welds at all, they held up perfectly. I did use a hockey puck with a slit down the middle though on my floor jack. Pretty sure this is the method I'll continue to use from here on out.
