jybyrd
- Seattle, WA
Here you go. Boost safety 28, FOL 55
Sent from my SM-G935P using Tapatalk
And my more aggressive absolute settings
I had my peak at 27 as well, but i was able to hold boost a lot higher in the RPM range and still got 10-11 degrees of timing up top
4500-26
5000-23
5500-21
6000-20
6500-20
7000-20
I played a whole lot between 5000-6500. I think depending on the weather i either ran 22,20,20,20, or 23,21,20,20.
Yeah, dragging boost up to 20 from an ECU requesting 9psi due to low IATs is difficult. Trims start capping out and it goes lean in spots (see my log above). Still gonna send it.
Just send it..
I'm curious about other people's experience with the boost reduction value. I have a DSG and always had crazy timing pull at the 3-4 shift from the overboost, sometimes 3+ in multiple cylinders. The Boost reduction value being set to 100 seems to greatly alleviate the timing pull, but at the shift, load is around 2-3psi under target. I guess I can't have my cake and eat it too. Here are my most recent logs. Anyone else using the boost reduction value and can share some logs that show the shift? Seems hardly anyone ever logs the 3-4 shift... Thanks!
https://datazap.me/u/gtiedge/28?log=0&data=1-3-4-21-25-26-27-28
Have you tried 90 or 80?
I've always had this problem of overboost in gear shifts. the auto shift boost redux parameter did not help me, I tested it in different values and it does not work with constancy, sometimes it reduces the boost in the gear input too much and the car ends up getting weak. My JB4 is very well configured, but the gear shifts could be better.
Yes. I started at 80 I believe, and i'd tried pretty much every value from 50-100. There was no difference with any logs less than 100. Some logs at 100 would look great as far as no timing pull, but the load would be so much less than target. Then I'd go to 95, and they'd be there again. The worse of the two logs I just posted as at 95, the other at 100.
I don't know if it's just something with my car, but load is almost always well above target, sometimes up to 0.8 psi over target. IDK if that's a good or bad problem to have...
