toledospeed
- 3rd rock
Yea, now that we've seen twice that the IS38 is different I'll add something about it to the instructions.
It's not that the IS38 adjustment is different per se, it is just that folks aren't interpreting and following the APR video instructions properly. Per the video (and in the instructions in the video description) they are expecting you to use VCDS to dial in the final adjustment. The initial adjustment in the video is just that, a starting point that gets you close. Many expect this to be exact, but it isn't unless you get lucky. What is important to note is that you should be doing the final adjustment before you put the downpipe back on. Otherwise, this puts you into a tighter situation like the guys found themselves in.
George also alludes to this in the link I posted above:
"A lot of people that have done the APR adaption have had issues, most likely due to not getting it right or there is something out with it."
http://www.golfmk7.com/forums/showpost.php?p=507387&postcount=23
APR Video:
https://www.youtube.com/watch?v=sne8-9svmN0
Video Description:
1 – Unbox the turbo.
2 – Loosen the jam nut on the actuator rod.
3 – Turn the rod until the wastegate door is loose. When it’s loose, it will wiggle freely.
4 – Slowly turn the rod to tighten the wastegate until the moment it makes contact with the turbine housing. When this happens, the wastegate will no longer wiggle freely. Don’t tighten it further.
5 – Using a marker, draw a line on the actuator rod.
6 – Using the line a reference, turn the rod one and a half times, tightening the wastegate.
7 – Tighten the jam nut.
8 – Install the turbo and plug in the wastegate.
9 – Leave the turbo accessible if further adjustment is needed below.
(in the video is says leave the exhaust disconnected)
10 – Flash the ECU with APR’s IS38 ECU Upgrade.
11 – Plug a VCDS (Vag-Com) cable into the OBDII port.
12 – Turn on the ignition, but don’t start the engine.
13 – Open the VCDS Program.
14 – Click “select” under “Select Control Module.”
15 – Click “01-Engine.”
16 – Click “Basic Settings – 04.”
17 – Select “First adaptation of charge pressure actuator” from the drop down menu.
18 – Click “Go.”
19 – The test will run shortly but for no more than 10 seconds, and the wastegate will make a high pitched noise.
20 – If the test was not successful, and listed a failure or abortion of the test, attempt loosening the rod 0.1 turns and try the test again.
21 – VCDS will say “Finished correctly” if the test was successful.
22 – Continue installing the turbocharger system, and enjoy the APR ECU Upgrade!
