[HOW TO PATCH Component Protection] MIB2 Technisat/Preh Headunit Patch(gps headunits only with 2 sd card slots)
ash9949
Poland
golf 7
answers
1. Yes the Bluetooth is working fine.
2. What do you mean ?
3. Factory equipment
4. MIBSTD2_Toolbox-v1.3.1
5. I have done this with the previous version (472T), without any luck. The FECs injected but were unsupported.
Generate fec for voice and try injection with obd2
Follow the video carefully
ash9949
Poland
golf 7
Giannis20vt
Greece
GOLF MK7.5 TDI
Thanks for the answer.
First i checked if the voice control is activated. It is so no luck to this one.
I will retry to inject the FECs for the Voice control and i will report.
Larson
France
Hi,
Since i patch my unit for cp off, i have component protection actived on my gateway is it normal ?
I can’t erase it.
Giannis20vt
Greece
GOLF MK7.5 TDI
I did the procedure.
the two FEC codes injected and seems to be Valid.
The voice control doesn't work.
I don't mind, as you said it isn't a very useful tool. Μy interest is purely academic, so there is no need to find the solution.
Giannis20vt
Greece
GOLF MK7.5 TDI
I had two errors for the 5F module (infotainment).
The B200087 (software incompatible) and the B126CF0 (navigation database)
For the 1rst one i followed the steps from this video:
Any ideas for the second ? The navigation system is working fine. Is this the problem with the CID number at the SD card ?
mr-fix
Poland
MK7 2.0TDI Variant
2nd is CID related. You will have this fault as long as the not original SD card with maps is inserted.
Larson
France
Hi,
Does my mib2 3Q0035846A patched is able to show rear camera and park assist in same time ? Because yet only camera is showed (bip pdc are ok)
Like this
Mine actual (garage door)
Larson
France
I made a test with a mib1 and pdc ops on my camera works, do you think my unit is defective ? Or hack can cause that ?
Larson
France
I check all, same on mib1.
I made same coding for pdc and bap and assist on the mib2.
I don’t know…
Maybe another coding block ?
This unit was mounted on a aw before it seems.
mr-fix
Poland
MK7 2.0TDI Variant
if you disable RVC_LOW in module 5F long coding, does parking sensor display works?
Do you have 8 sensors (4 front and 4 rear), 12 sensors (6 front and 6 rear) or 4 sensors (4 just rear)?
Larson
France
Hi,
I’ll test today for rvc\low, for sensors only 4 rear.
