wave
- SW Florida
I would agree with this but it depends on how you drive. I think I would want the gas pedal as low as possible, because when I'm threshold braking at the track, the brake pedal is pretty far down making it hard to get the other part of my foot over to the gas.
Thanks a ton for posting those pics, I'm for sure going to buy and install that. And OP, I wish you luck on your DIY. Always nice to be able to make things however you want and to your personal liking.
I understand that. I think for me, the brake is already too close, so I had to raise the gas to be comfortable. Also, I have Brembo's on the front of the car and aggressive EBC pads all around, and with the BBK my brake pedal travel has been reduced significantly. I have more pedal travel in my gas then I do in my brake by far. So this problem you describe isn't an issue.
No problem, I hope it works for what you are looking for. Also, I would recommend you remove the pedal to install this one, it's much easier to get the straps on and tightened securely. The instructions are very good and I just followed them for the most part, with the addition of some thread lock on the screws.
