Got a bad turbo? Let's track the issue...
wy2sl0
Ontario
I thought it's a hybrid?
Good call, thanks. Just read their website and it is indeed a hybrid. The compressor and exhaust wheels are considerably larger. Powerband will shift right though for sure.
VTT's option out in a few months too. Good to see!
WOLF
San Antonio
MkV GTI
How is flow different from volume? I have no idea how the oil pump works on these cars. Are you decreasing the pressure by increasing the area?
Unless oil pressure and/or the narrow feeder line diameter is increased, the volume of oil pushed through the turbo remains largely unchanged. Decreasing restrictions in the cartridge allows the oil to reach the bearings faster and evacuate easier back into the pan.
railroader
Yuma Arizona
A little off topic but hey wolf do you have a electric waste gate you would be willing to sell off a blown is38
Sent from my XT1254 using Tapatalk
railroader
Yuma Arizona
Hey bud do not have one right now.
Ok if you come across one please let me know.
neproracer
United States
well I have turbo off. wow. lots of little torx bolts to keep track of. downpipe came off very easy, and for the most part everything did, even spark plug boots,,, I was worried I might brake them apart.
? should I get a, or 2 o2 spacers' ? running usp catless downpipe.
? do I really need a bigger intercooler if I'm not a "racer type" I jump on it just to scare my daughter or girl friend, cant scare the girl friend .
iNeedMorePSI
I see so much back channel talk and stuff on forums I have to chime in with info and a brief history lesson. Littco(Dan) doesn't advertise what he actually does to be successful on this turbo. Littco has already made custom thrust/journal bearings and machined inserts to replace ceramic. Has already machined the CHRA. Has already made a ceramic dual ball bearing conversion for our factory turbos. The problem is some people are coming late to game and has taken ideas from his designs(oil flow and bearings) or figured it out as TTE hasn't even address this issue like Dan has. Now none of these people you see pushing hybrids today have these turbos running for months and thousands of miles. They are selling you an idea on the backs of the pioneers who paved the way already.
Dan Little was the first to offer various wheel sizes over TTEs 2 options. He did not even steal TTEs design either but instead made his own better design and wheels. On quality and longevity I assure you and anyone during the protoyping phase can assure you any turbo that were discount bought from Littco and blown were prototypes and were replaced with revised internals/work done. Out of these 7 units 3 popped and there were no NDAs to keep people from crying about it either as there shouldn't be. The other 4 prototypes are still running many months later. 1 just hit the dyno putting down low 400s on stock fueling, another weeks ago put down the similar whp on stock fueling. Both on IS38 files and jb4 stacks, then 2 other custom backends have made 430-450whp. For the revised internals 0 have failed to date. So if you have a Littco turbo(like ACE on this forum) put it on and stop whining, if it pops Dan replaces it but at this point you would be the first out of dozens to pop.
That said in my possession I have the markets first ceramic DBB conversion of oem CHRA from Littco, not to be confused with an entirely new CHRA that is DBB ie Garrett core. It is easily over 450whp spool by 3200rpm turbo based on the journal bearing version data of this spec. It has a machined housing, custom machined oil restrictor, VSR balanced, point milled 7/7 blade next gen aero profile wheels. It is a 1 of 1 unit and will be dialed in by COBB 5150 solution.
On to pricing; journal bearing work by Dan is very affordable with quality parts, machining and VSR balancing. That cost $800-900GBP. For ceramic DBB add another $300GBP or so. In USD that is like $1200-1500 shipped back to you. Tell me who else is doing this work at this cost with someone who makes things right when things go wrong and not place total blame on customer?
Enough about hybrid turbos. What abput NEW turbos? Over the weeks I also talked to another company who was making MK7 turbos that would put everyone out of hybrid turbo business (besides Littco due to Dan doing DBB option, bespoke sizes and at affordable cost). I've used them for almost 3 years on my track Evo in the past and have confidence in them as much as I do Dan Littco in building a reliable turbo. They came to the market recently with a very affordable solution for us. Want to have your mind blown? VSR balanced and custom made chra and housings. Just read the description. https://www.maperformance.com/products/tomioka-ihx475-jb-turbo-kit-multiple-fitments-tr-tw1002
There you have it. So if you don't already have a used IS20 or IS38 core and/or want custom wheel sizing or ceramic dbb conversion from Littco at an affordable price. Go to the next best thing, I would advise everyone to buy a Tomioka setup. You're welcome.
Bonus info: if you want a baller billet chra replacement(like Xona but not a Xona) I have specs for that too that work with stock housings at half the price. LOL
Sent from my SM-G935F using Tapatalk
Gawernator
Fremont, CA
That looks sick.
iNeedMorePSI
That looks sick.
I know right. Game changer. No more need to buy cores for crazy prices and send out unless you want a bespoke custom setup or dbb conversion. Plus comes with all the extra goodies.
Gawernator
Fremont, CA
The only annoying part is if you have already have those parts.. double paying
Oldschoolmk7
Yonder
So how much power on stock fueling can a Litco is20 hybrid make on 93 pump? Have yet to see dyno's etc? I'd be up for $1200 range on this one. Would it outperform a stock is38?
Gawernator
Fremont, CA
For the time and money I don't see how it would be worth it vs IS38 base.
demi9od
NC
How many turbo options were there 3 months ago? Turbo releases for the MQB seem to be coming fast and furious lately.
Sent from my HTC 10 using Tapatalk
Gawernator
Fremont, CA
Almost.. 2 fast 2 furious....
shoot me
