cb1111
Newbie
- Virginia, USA
Huh? Do you know what PDI stands for?PDIs come with tires over inflated on purpose and oil is usually .5 quart low. Everything else is up to the tech to check over.
Eight VWs since 2015. 7 new and current one CPO. From three different area dealers. Not saying there aren’t screwups occasionally but I’ve had zero problems on any of mine. And I‘m meticulous. I realize forums are in many cases for complaints.
Same could be said with our 4 from 2014-2020, people look at me funny when I say we’ve had 4 since 2015 model year. But yeah 8 is certainly a lot and I didn’t realize Dequardo had had that many.8 VWs since 2015...why?
I feel for you. Many would have sworn off the brand with that history. Hope you get everything sorted
not intending to insult but why didn't you check fluids/pressures on day 1 (or 2 if you picked it up at night)?
you may be right....tires inflated to 40-50 psi cause they will loose psi over time and dangers of high are way less than low. the 1/2 qt less cause cost savings and still within tolerance.PDIs come with tires over inflated on purpose and oil is usually .5 quart low. Everything else is up to the tech to check over.
lol yes. why? Probably because I'm a technician at VW. You think cars come perfect from the factory? lolHuh? Do you know what PDI stands for?
^^^This is exactly correct. If the car ends up having to sit at port for who knows whatever reason, and its easier to lose 20psi from a tire inflated to 45, 50psi than a tire at spec at 32psi. Then you're out 4 tires. Tires are more expensive than air. Also yes, if you're putting 6 quarts of oil in thousands of cars, dropping .5 of a quart off is gonna save you some money and still be within spec. And then the dealer ends up covering that cost of the missing .5 quart.you may be right....tires inflated to 40-50 psi cause they will loose psi over time and dangers of low are way less than high. the 1/2 qt less cause cost savings and still within tolerance.
See my comments in bold above.lol yes. why? Probably because I'm a technician at VW. You think cars come perfect from the factory? lol
You may be part of the problem then as you seem to think that PDI is a thing - like a spark plug or a tire. You said "PDIs come with tires over inflated on purpose and oil is usually .5 quart low. Everything else is up to the tech to check over."
Cars come from the factory with tires over-inflated.....and the PDI is a process to bring everything on the car into spec.
The oil filter doesn't have much oil in it.Was the oil checked with the engine hot or cold? If it sits too long it seems the oil can drain from the filter. I don't know if there's a check valve that's supposed to prevent it.
If you don’t know if there’s a check valve how can you say it ‘seems the oil can drain from the filter?’Was the oil checked with the engine hot or cold? If it sits too long it seems the oil can drain from the filter. I don't know if there's a check valve that's supposed to prevent it.
Hint. There’s a check valve.
That's what I figured the rod was for, but it seems it doesn't seal 100% after the car sits for a week. Can you figure out why I say that?
It's really irrelevant anyway. With the filter in the housing it only holds about 6 ounces of oil.That's what I figured the rod was for, but it seems it doesn't seal 100% after the car sits for a week. Can you figure out why I say that?
we're saying the same thing....See my comments in bold above.
