Hi.
Have EU version MK7 Estate, 1.4TSI 103kW manual. Electrical "handbrake" and kessy.
My car doesn't have separate button to disable ASR. It can be done via Radio OSD, Car-Setup.
Tried this coding with VCDS 14.latest (not beta) with no luck. Changing byte 29 always fails, esc and brake light start to flash in car dashboard. Changing ESC mode via radio OSD also fails 'function not available'.
The car has to be shutdown to remove esc&brake light flashing. ESC always stay on.
I tried the coding the car running, or
I can paste my VCDS coding info from my car and some VCDS photos if needed.
Would like to have some help to remove ESC from my car...
I also tried the other tip to change the car to bench test mode. With that I got warning tone, ESC off to dashboard. ESC was off for maybe 10m and then kicked back in. Didn't test this again to confirm.
There is a option in 03 ABS brakes -adaption-electronic stability control: activated/not activated. In my car it was 'not activated'. Didn't test changing that value.
I've learned from German forum that ESC can be disabled by coding with another cable and software, VCP http://www.vag-tech.eu/
But I'm hopeful that somehow it can be done with VCDS....
