just had my switch's out & half the surrounding trim!!
Now I have no pin 9 or pin10 wires!!..................so according to the wiring diagram you provided pin 10 goes to A38 positive connection 2 (15a) in dash panel...where is this connection??
Golfdave: Hi, and I'm happy that you were able to source the console switch - does it have a 10, or 12 pin connection?
Before I proceed and please don't take this the wrong way but I have to say (again) that the wiring diagram in my previous post
is a replica from VW's database (it's not my wiring diagram that I put together from my guess at how the ESP switch works). I provided the wiring diagram as a courtesy in answer to a forum member's question.
The only change that I have made to VW information is to show on the one diagram how pin 9 of EX23 is connected to J104. This modification to VW's original diagram was a simple cut-and-paste- so I have made no change to the data in VW's circuit description. Had I not done this, I would have needed to post multiple picture of the ESP circuit which would have just complicated the reader's understanding (IMO). I think that the diagram is easier to read because all of the information is contained in the one picture. My motivation in highlighting these points is just to make sure that we both understand the responsibility that I take in your project. That said, I'd like to help if I can!
OK, back to your question. It's not surprising that the purple/green wire is not present in your car. The days of car manufactures installing standard looms in their cars with un-used wires are long gone! And, I suspect that the revelation came as no surprise to you - given the last line in your previous post #79.
To help with your
A38 question, I have included below an extract from VW's training material on wiring diagrams. It shows how VW describes connections such as circled A38 on my previous pic. As you will read, these are soldered connections within the wiring loom. From the other wiring diagrams that I have for the mk7, it appears that A38 is a significant connection in the dash panel loom as it's mentioned in a number of circuits.
Again, this is your project, but why try to find this point in the wiring loom in the first place? My experience has been that soldering a new wire to these points is invariably difficult! Getting good access to make the solder joint is often tricky and re-insulating the finished joint is messy!
Instead, why not connect to pin 11 of T12am (assuming that you already have auto-hold switch on the console)? If you don't have this switch, tell me what switches you do have on the centre panel, and I will try to find an alternative point for you in my wiring diagrams.
Edit: the one thing that worries me about your project is how you tell the ABS controller that you have connected an ESP switch to it. I've just had a look at the adaptation channels and the coding string settings in address 03 ABS control module. There appear to be no ESP switch related entries in any of the adaptation channels. I would have suspected that I would find this facility in the Coding string. The problem is that RT's software currently doesn't provide support for the Byte settings for 03 ABS module using the Long Coding Helper. So I have no idea which Byte/Bit does what! Not certain that you would need to do a VCDS tweak, but it's normally required when adding a new wire to the BCM. Sorry that I can't be of more help here- perhaps someone else here has some information that would be of assistance
