Getting DG springs fitted to my DCC Gti tomorrow, will post pics and height variation info here for future reference.
Would others with DG springs please post pics of their setup,
Thanks in advance,
Ben.
Yes. And I'm pretty sure there is a problem.
Ordered the Zubehör springs at the dealership. Parts manager entered the car's VIN and the computer told him (so he says) to use the 5G4 071 677 C set. That's what went on the car.
Car nos sits with significant rake and imo, the front springs are not hard enough. The suffix C set is rated at 930Kg. Much lower than the specified 1020Kg.
So, the question now is: to go with suffix D springs (rated at 1010, so 10 under spec), or with the 5G3 071 677 E springs which are rated at 1050.
Note, all three sets share the same rear specs, at 890Kg, an almost perfect match to the car's 880 spec.
Will be back with more info when the fronts are swapped.
Interesting, I didn't' realize the DG's came in different flavors. I used suffix "E" on my regular North American 2015 Golf 1.8t and specs match what you stated for the E's (TUV shipment papers matched as well):
https://deutscheautoparts.com/5g4-071-677-e.html
I think you will like the 1050kg rated fronts much better. I'll stop back for updates
Boomer, that looks like some serious negative rake. Did you use the DG "E" springs?
How's the ride compared to the stock GTI springs?
Ride is no different from stock. Pics were taken right after install two weeks ago and now the car sits very level.
