GTI Jake
- Charlotte, NC
Thanks man I'll see what I can find
I got mine at FastenalThanks man I'll see what I can find
I believe it's m5x1.0 but I'll double check later when I get home
Sent from my XT1254 using Tapatalk
If your capable of doing it yourself then I say do it. It's not hard. No I can have the transmission out in 1 1/2 hours or less, putting it back in was a little more difficult cause my tranny jack is garbage and don't work well for transaxle. The most tedious part is tightening the pp down cause the are 27 bolts and have to go star/criss cross pattern to tighten and only tight each one 1 turn at a time then once it's all seated take each bolt out one at a time and put loctite on and torque to 10ft lbs. I have to pull mine out again to change the TB/slave assembly again.How long would you say it took you to install the DKM clutch? I’m on the fence as if I want to do it myself. My concern is if the install went south, that it would take time to get it right. I work a lot, and don’t always have time on my hands, but considering trying it because shops want to charge me $650+ for the install, up here in UT. I do have a garage, but I don’t have a lift, or a transmission jack. I just have the tools needed to remove/install, and jack stands. Is it worth tackling it myself to save $$ for a shop to do it?
I will double check when I get home on the thread but I'm almost positive that's it and they are 3/4in long or about 19mmDid you ever find the exact specs for these bolts, so that I could also buy some stronger ones to install when I get this clutch?
That joint where the clip is where it leaks from. It is very flimsy. They are sending me everything minus flywheel and it will be here tomorrow. I'm going to put it all together and see if the current clutch works ok. I sure no fluid got on the discs to contaminate them so I will have an extra set of discs and a pressure plate.
Yes. Dkm said there was no difference between the 2. I ordered a oem to put in now after I pull it back out. Comparing the 2 side by side the oem one looks like better build quality. I'll look for the email when they told me thatWould the OEM throw out bearing work with this DKM Stage 3 clutch? Just wondering if I should buy the OEM TOB and use that instead of the one DKM provides, just so I don’t get this problem during the install.
Your probably right. After the first tb problem I am probably just being a little anal on the noise. I sent Dkm a video of the noise and they think it's chatter which it probably is but idc I'm not pulling the tranny again until I have to or I break something. I just want to break it in so I can put my is38 in.I started paying more attention to my stock clutch noise. With BFI stage 2 mounts there is a TOB noise unless the clutch is in. Maybe what your hearing is normal but focusing on the clutch made it more noticeable
I know it has that little spacer. I have also read that the oem one will mellow out the chatter but I'm not putting the oem one in until I have to pull the tranny back out. So it's all straying in there till I break something. Dkm said there would be no issue with the oem one. I just want to be done so I can put in my is38I would not install the factory TB with this kit. It has a spacer on it. This will move the engagement up on the pedal, possibly causing over engagement of the pressure plate.
I would check that DKM sees that and can be 100% that it's okay.
I just hit 400miles and are having the same clutch stutter as you, as the miles keep going it's less and less. Can't wait to turn my car back up!
