Each time you turn the ignition off you see "Check SAFELOCK! Owner's manual!" message which looks like a fault but actually it's just a reminder that car is equipped with deadlocks - once locked you can not open the door from inside (for example after breaking the window).
If someone stays in locked car it's a safety hazard as there's no way to get out from the car. There's a button on the drivers side B-pillar for one-time turing this off.
So that's the reason for the reminder. Here's how to disable it.
MK7:
MK7.5:
MK7:
Code:
Module 09 → Security Access → Code: 31347
Module 09 → Coding → Long Coding → Operation mode 2 → Byte: 08 → Bit: 6 → enable
MK7.5:
Code:
Module 09 → Adaptation → ZV allgemein → ZV_ohne_Safe_Funktion → installed
