Gawernator
- Fremont, CA
Yea i m hearing mixed reviews as well, still deciding if i shud heat wrap or turbo blanket.
Sent from my HTC 10 using Tapatalk
I'm not doing it because of the chance of an engine bay fire.
I finally got to try the piggie pipe with some e30. It did really well. The cooler weather certainly helped as well. Did some runs against two friends with GTIs. One is a JB4, downpipe and the other is a JB1 at 5.6 with a downpipe. Both are dsg, e30 and pedal boxes. They would get the initial jump on me, but then they would only slowly pull away. I hung in pretty good. I think the pedal box helped them with the jump. From 40-110 I was only back about 2-3 cars max. I was able to get a log and it looks really good. I think I can add a little bit more to it.
http://www.datazap.me/u/jcranwell/e30-piggie-pipe?log=0&data=1-4
How have you seen performance improvement with the colder plugs?
Here's a link to my logs - http://www.datazap.me/u/mattkime/
I did 3 logs on map 4 and 3 logs on map 1. It was my first attempt at logging. I made sure I was in 2nd and then tried to floor it until i was in 4th - although I think I still need to find a better road for this.
Is there anything notable in the logs?
Where should I start with map 6?
One of my first Map 6 Logs. The car feels pretty strong. I'm starting to see some timing values in ign2... I'm coming up on an oil change (5k interval) and then we'll see what it does at the strip!
http://www.datazap.me/u/17s/log-1505181266?log=0&data=1-3-4-11-14-18-25-26-27-28-29
@MeltedSolid and other JB4 smart individuals, does the FOL setting affect low load or lower rpm AKA everyday driving or fuel consumption or is it just under heavy throttle?
Wind it out to 6500 next time.
Looks like you need to dial it back a bit. Not even hitting target and multiple corrections as you hit 5k.
I would like to wind it out more in 3rd for sure. Still hunting the perfect stretch of road.
Thanks for the tip about dialing back.. I will do so!
