It feels a tad bit faster, but no more than the jump from APR to stacking with the JB4. That being said, when I took the log it's peak boost was slightly higher than I had ever seen and it was holding around 1psi more at 6000rpm, which feels about right. Thankfully I was able to log in almost the exactly the same ambient temperature as the first time I logged with map 4 and just APR stage 1 (10 C vs 10.5 C), and the IAT after 4000rpm is virtually identical, so this is a very good comparison. I also decided to look at the lag, and while it felt basically identical while driving, apparantly it took ~3s and 900rpm to build to max boost from 1900rpm vs ~2.2s and 650rpm with the IS12. I was surprised the difference is so great in the logs because it really doesn't feel like much when driving. I guess more importantly it's capable of easily reaching it's target boost at considerably less than 3000rpm, which is very impressive for so much power.
I'll try a write up, as I think I can currently run through all of the steps in my head, but I didn't take many pictures so I would need to work with what I have.
An IS20 swap takes a LOT more time and effort to perform than just a downpipe swap, but if all you care about is the price per performance (like me) then an IS20 swap would not only have a greater power yield than a downpipe, but is also cheaper than the average downpipe. Who would have thought that one day upgrading your turbo would be cheaper than upgrading a piece of piping! This turbo swap is well worth it!
