The turbo is in the car!!!!
The oil drain line is much easier now with the included hose to replace the factory one. This makes taking out the oil drain line easier since now you can just cut the factory rubber hose as it’s replaced with a longer one in the kit. I cut it out of frustration when I was uninstalling my dead because reaching where it connects to the block with the turbo in and removing it is a pain. Now just cut it then pull the fitting out of the block when the turbo is removed, makes it much easier.
The coolant drain lines connect much easier since they include a hose to extent the one people where having issues connecting.
I’ve still got to do a lot more work before it’s all back together but the main and most difficult parts are done.
I did get an update from modded euros it is a new revision and they haven’t released any info on it. Mainly to make install easier by relocating a few things and including a couple different things. They did ask I not talk about it, oops too late. Here’s the quote from the email it made me laugh “This update hasn't been officially announced yet by CTS so they asked if you could keep it quiet until it is formally released.”
Sounds like I got lucky and probably got one of the first new kits they sent out.
Hopefully it’ll be done by the end of the weekend.
