MidnightinGotham
Would anyone happen to know what the latest TSB number is?
I'd like to know that too. And is there anywhere to look these up (get more details)?
Does anyone have sunroof rattles from the front? Most posts that I have read are regarding the rear lip.
My sunroof has a rattle above the console, sounds like sunglasses rattling in the compartment. I removed the entire console, lights, etc, and it still rattles. I can make it stop by opening the roof in either position, or by pushing up on the glass (front) with extreme pressure when it's closed.
Just had mine in for the creaky sunroof. Apparently there is a New TSB procedure that addresses the plastic piece that the sunroof seal rubs on. Should have it back in shortly when the parts arrive.
Do you know the TSB number, I would like to go to my dealer with that information rather than them telling me there is no TSB.The parts came in yesterday, so i dropped the car off this morning. I had the service adviser show me what parts showed up under the TSB. Turns out they got 2 sheets of PPF material.
Thanks in advance.
I'd like that for reference as well please!
come on guys, read the thread comments. lube the rear sunroof weatherstripping with some sil glyde. You can pick some up from Napa for $14.00
https://www.napaonline.com/en/p/BK_7651346
This will fix the rattling and creaking when going over uneven surfaces or crappy roads. I had the same issue you all are complaining about. I had the "rattling" sound from the center console. This fixed the issue. Car is silent now.
Come on guy, read what's been posted. I've tried all sorts of lubricant and it helps for about 5 minutes if that.
Don't be a condescending ass. My post wasn't specifically aimed towards you. Gummi Pledge will not work for the sunroof rattling/creaking. If you use what I posted, it will resolve the creaking/rattling sounds. Make sure to get the teeth as well.
